10-08-2014, 10:06 AM   #1
csa's Avatar
Remote for K50?
I see many Remote controls for Pentax; which would you recommend for my upcoming K50?
Thanks!
Carol
10-08-2014, 10:21 AM   #2
I brought an eBay one(one button 2-3 dollar version) and it works
10-08-2014, 10:28 AM   #3
JimJohnson's Avatar
Are you more interested in wireless IR or wired remote shutter release? Both are supported and both have pros & cons.
The IR releases are small and travel easily. They are great for 'selfies'. From what I can tell, the range is no better for the official Pentax IR remotes versus cheap 3rd party versions. And speaking of range.... the sun is a huge IR emitter and while it won't fire your camera, it messes with a remote's signal. The brighter and more direct the sunshine, the shorter the useful range of your IR. Battery strength in the remote also impacts range. While you can use a reflector (shortening range), they work best when aimed directly at the receiver on the front of the camera.
Wired remotes don't use batteries unless the remote supports a special feature*. You are not limited by your orientation to the camera, but your range* is limited to the length of the cable (plus any extension cords). Wired remotes take up more travel space than IR remotes. Again, there are a number of very nice 3rd party units that cost very little. Pentax and (most) Canon cameras use the same 2.5mm stereo connector with the same wiring. The sun has no impact on a wired remote.
*speaking of special features... there are a lot out there including intervalometers and wireless. The wireless models usually use a receiver that plugs into the wired socket on the camera and a remote transmitter that uses a non-directional radio transmitter unaffected by the sun. If you have a cell phone or tablet, do a web search for TriggerTrap. You'll be amazed at how many ways you can remotely control exposure on your camera.
10-08-2014, 10:47 AM   #4
kchamber4's Avatar
I have used two different 3rd party remotes and both work fine or me. They have two buttons. One to fire and another supposedly for adjusting the zoom (which doesn't work and I don't care). I also saw one at Target for 9.99 USD that said it would work with Pentax. it had 4 or 5 buttons / functionalities. The remote was from Targus, I believe but can't confirm right now.
10-08-2014, 11:22 AM   #5
csa
csa's Avatar
Thanks everyone; I would probably go with the wired one, as space (compared to wireless), doesn't affect my circumstances.
10-08-2014, 11:42 AM   #6
esrandall's Avatar
I use this one:
http://www.amazon.com/Vello-RS-C1II-Remote-Switch-Samsung/dp/B007CB58NY
Cheap and has a decently long cord. You can tap it for autofocus, as well as slide the button into position for a bulb exposure (so your thumb doesn't get tired.
10-08-2014, 03:20 PM   #7
This is the wired remote I use.
Bower LCD Timer and Remote Shutter Release (Model RCLC1R) reviews - Pentax Camera Accessory Review Database
The intervalometer features were nice on my K10D, but not needed on the K-3 unless I want to to something complicated like programming bursts at interval or a series of exposures for longer than 30s. The real nice thing though is that it can be programmed to do a time exposure of arbitrary length.
10-08-2014, 03:26 PM   #8
csa
csa's Avatar
Steve, thanks for that review!
k-30, k-50, pentax k30, pentax k50
Spare battery for K50 csa Pentax Camera and Field Accessories 19 11-10-2014 08:05 AM
Firmware for k50 Gerrys Troubleshooting and Beginner Help 2 09-02-2014 10:38 AM
Camera Strap for the k30-k50 kshapero Pentax K-30 & K-50 37 04-12-2014 01:48 PM
Cable release for K30/K50 Relativity Pentax K-30 & K-50 6 04-08-2014 11:53 PM
Sigma 150-500 for my K50? Kath Pentax SLR Lens Discussion 16 03-05-2014 06:19 PM
All times are GMT -7. The time now is 01:46 PM. | See also: NikonForums.com, part of our network of photo forums!
