10-31-2014, 01:09 PM   #1
older lens on k-30....help with settings.
I know there must be a post or sticky on using older pentax lens on a new k-30 body ?
I have ........ Super Takumar 3.5/35mm.... WITH auto/manual switch
SMC Pentax 1.8/55mm WITHOUT any Auto/Manual switch
Ricoh XR Rikenon 2.8/28mm WITHOUT any Auto/Manual switch
All these are usable and fantastic lenses. However Im not at all certain about camera settings using these older lenses , and what functions and modes work and don't ? Metering ? modes that will/wont work etc. Preview using green button ?
Any help , or links would be greatly appreciated as I want to learn the Ricoh 28mm lens the most and the 35mm secondly Im getting lost without the manual giving much info................Thanks !
10-31-2014, 01:15 PM - 1 Like   #2
QuoteOriginally posted by az1895 Quote
Here's the guide:
https://www.pentaxforums.com/forums/54-pentax-lens-articles/110657-how-use-me...k-x-k-7-a.html
That should get you on your feet, let us know if you have any other questions
10-31-2014, 01:17 PM   #3
jatrax's Avatar
Here you go:
https://www.pentaxforums.com/forums/58-troubleshooting-beginner-help/110658-u...x-dslrs-f.html
The Super-Tak will require an adapter.
The SMC Pentax 55mm should work as is assuming it is K mount
The Rikenon, I do not know. Is it K-mount or M42? If K-mount you might want to check for the Ricoh pin which in some cases can cause problems. I am sure someone with more Ricoh experience than me will chime in on it.
10-31-2014, 01:33 PM   #4
They are all K mount even the Ricoh. The Ricoh doesn't have the problematic pin.
Thanks for the help ! Now I have to go sort it out in my mind.....lol.
11-02-2014, 12:52 PM   #5
With my Macro-Takumar, I use a Pentax screw mount adapter ring. Because the lens has only aperture and focus rings, I set the K-30 for full manual operation. The metering still works but the lens must be manually stopped down prior to exposure. These older optics are excellent and inexpensive but require a bit of thought.
auto/manual, k-30, k-50, lens, lens on k-30....help, lenses, pentax, pentax k30, pentax k50, ricoh, switch
Aperture ring with manual lens on K-30 Tsuken Pentax K-30 & K-50 12 11-30-2013 09:19 PM
K-30 with older lenses rmat Pentax K-30 & K-50 23 01-30-2013 11:45 PM
Older lenses on a K-30 jcdoss Pentax K-30 & K-50 18 12-21-2012 05:01 PM
Question about lens settings on an older flash robert Flashes, Lighting, and Studio 4 05-11-2012 07:07 PM
I'm unhappy with K-7 settings. Help me custom the settings like k20. netuser Troubleshooting and Beginner Help 16 09-01-2009 08:39 AM
All times are GMT -7. The time now is 05:23 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
