Hello,
Unfortunately, the K-30 does not have an HDMI connection. If your camera came with a cable, it has the one connector that plugs in to the camera, and the other end has two plugs, yellow and white. On the back / left side of your TV should be a block of labeled AV IN. The yellow plug from the camera should connect to the far right plug labeled Video or Y. The white plug would go to the Audio L (or R) connector on the back left of the TV.
Since your TV is Smart TV, you may be able to plug in via USB and play the files that way. But I don't think it will be real time.
I don't own the K-30, or the TV. This was just from a quick read of the two manuals (for fun).
I hope this helps
