11-08-2014, 07:19 PM   #1
Setting up K30 User modes - is this combination possible?
I want to set up one of the User modes on my K30 so that I can take a series of photo's that are exposed at 0, then + 0.5 stop and + 1 stop. And I'd like to set the second one up doing the same thing but under-exposing by 0.5 and 1 stop. From what I've found by looking through the menu, the bracketing function won't do this sequence, it will only do zero, plus and minus stops (or a combination of that).
Is there a way to set up the sequence I'm after?
11-08-2014, 08:07 PM   #2
My camera isn't with me right now, but can't you just set your default exposure to -0.5 and select bracketing at half a stop above and below your current exposure?
11-08-2014, 09:53 PM   #3
Canada_Rockies's Avatar
Pentax bracketing can be offset. The -1, 0, +1 sequence can have the 0 at a different exposure using the +/- for the original exposure, which will then become the 0. To do what you want for the first user mode, set the bracketing to -0.5, 0, +0.5, and then set the exposure at +0.5.
combination, k-30, k-50, k30, modes, pentax k30, pentax k50, sequence, user
Is This Even Possible? LOL magkelly Pentax K-30 & K-50 17 10-22-2014 10:40 AM
PP manipulation. Is this possible to do? Dewman Photographic Technique 6 09-10-2014 01:50 PM
Is this a setting issue or is my camera broken? Newtophotos Pentax DSLR Discussion 10 01-13-2014 08:39 AM
K30 mirror up, what is there, should it be like this? Danas_Anis Pentax K-30 & K-50 3 07-13-2013 02:46 PM
Is AEB for K30 possible with remote cable? DuncanP Visitors' Center 4 01-10-2013 07:58 PM
All times are GMT -7. The time now is 10:59 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
