12-08-2014, 01:12 AM   #16
Not a Number's Avatar
Look at the relative positions where the contacts are on the camera mount (facing you) - say from 6:30 o'clock to 7 o'clock. On the lens mount facing you relative to the focus indicator mark that would be 5 o'clock to 5:30 o'clock . You usually only need to short the data pin which is closest to the mount locking pin. If you have trouble visualizing where the contacts are use a china marker or something non-permanent to point where they are located.
12-08-2014, 01:04 PM   #17
QuoteOriginally posted by OldChE Quote
Could you post a picture showing exactly where the foil should go? I'd like to try the same thing.
It's easy to put the tape on, assuming the lens has enough diameter to cover the pins.
In the pic below, the lens is a Mamiya/Sekor 55mm, f1.8, and the foil works fine.
On my SuperTak 35mm f3.5, the lens diameter is too small, so the green button method doesn't work.
12-10-2014, 04:38 AM   #18
Hello,
I had the same issue with my K30 and the Super Tak 55/1.8
Thread here : https://www.pentaxforums.com/forums/151-pentax-k-30-k-50/272457-manual-mode-issue-k-30-a.html
12-12-2014, 08:04 AM   #19
You can buy metallic tape at auto parts shops.
Maybe....but aluminum foil and a wider rubber band work good too !
12-12-2014, 09:55 AM   #20
QuoteOriginally posted by az1895 Quote
Quite true but some people would like a more permanent or elegant solution.
12-12-2014, 10:08 AM   #21
Very tue....I just sold my two Tak's and upgraded to some SMC-K Primes. That solved it for me......Kinda anyway....untill I found out this is only a K30/K50 issue and they would have worked properly on the new K3....
It looked kinda shoddish with a roll of aluminum foil and a rubber band....kinda looked broken...lol........I didnt like it either.
12-17-2014, 03:57 PM   #22
az1895 - why would the M42 Taks work on the K3 and not the k30/50s? How about the K5s or the new KS1?
button, camera, foil, hassle, k-30, k-50, k50, lens, love, m42, pentax k30, pentax k50, post
Using a fixed aperture manual lens and green button ripper2860 Troubleshooting and Beginner Help 12 06-06-2014 09:25 PM
K50 Screwmount Metering Issues: Green Button Meters in LV but not in VF Relativity Pentax K-30 & K-50 5 01-31-2014 10:17 AM
Please help - Kr, M42 + green button Unregistered Visitors' Center 13 04-21-2013 04:28 PM
Mirror flopping when metering w/ green button and old m42 lens Philoslothical Troubleshooting and Beginner Help 15 10-22-2011 05:06 PM
All times are GMT -7. The time now is 03:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
