12-12-2014, 05:35 PM   #31
aleonx3's Avatar
QuoteOriginally posted by tuggie76 Quote
But how would I know what to limit it too? To low and underexposed, too high wouldn't matter I guess.
Tuggie76
That all depends on what situation, say you are shooting an air show at night... first, you need to set to spot metering, otherwise, you will over-expose no matter what as the sky is dark. You set you shutter depending on the object, you set your aperture (don't push it too wide-open otherwise you don't have enough DOF), you set your iso range to something you can tolerate for noise, say 1000 upper limit). You chimp and once you get comfortable, then you save your setting to USER mode call it "night time air show" and ready for next time. Hope it helps...
12-13-2014, 05:14 AM   #32
QuoteOriginally posted by aleonx3 Quote
Thanks Aleon, that is what I did, except for limiting ISO, maybe I'll try that next time.
By the way, that shot was taken at Hamilton last june.
Tuggie76
12-14-2014, 04:30 AM   #33
800 is my limit in TAV mode. Fully manually sometimes 1600 when I am sure that there is no other way around it. But usually I even try to avoid 800...
12-14-2014, 09:24 AM - 1 Like   #34
AquaDome's Avatar
With the K-50, I try to keep it below 6400, but if I see Bigfoot in the moonlight, I could push it further.
ASA1600 film is difficult to work with. A lot of grainy pictures either over or under exposed.
Being able to add two stops to that and still get pictures is simply a miracle.
Being able to keep my DoF in low light is just a bonus.
auto, iso, k-30, k-50, pentax k30, pentax k50
Is there a auto-lens retraction setting for when camera is turned off? harioharima Pentax K-01 10 02-21-2013 05:27 PM
Auto ISO parameter, what is it? djc737 Pentax K-5 5 02-04-2012 12:08 PM
K-7 ISO 1600 - What is the maximum size print we can make? raider Digital Processing, Software, and Printing 7 11-23-2009 04:53 PM
Maximum LBA- what lens would YOU sell your soul for? JMS Pentax SLR Lens Discussion 15 04-16-2008 02:47 PM
What is your favorite K10D Jpeg setting? anthropas Photographic Technique 19 08-16-2007 09:16 AM
All times are GMT -7. The time now is 04:02 PM. | See also: NikonForums.com, part of our network of photo forums!
