11-21-2014, 05:19 AM   #1
dakight's Avatar
K-50 Lens Question
I have an old SMC Pentax-A 50mm f2.0, manual focus, of course. I have used it a couple of times and in one case noticed that it was reported in the exif as "35mm." Last night I was preparing to copy some old slides; when I attached the lens a dialog popped up on the screen asking me to enter the focal length. I, of course, entered it as the correct 50mm. I assume the camera firmware recognized it as an unknown lens but why not the first time I used it?
11-21-2014, 05:36 AM   #2
Tony Lens's Avatar
This dialog is showing up every time i use my M lens. Im not sure why you havent seen it the first time.
11-21-2014, 06:05 AM   #3
QuoteOriginally posted by dakight Quote
The camera asks for the focal length in order to be able to make the shake reduction work correctly,
since it has to translate gyroscope angles into pixel shifts.
If you don't have shake reduction on when you attach the lens, it won't bother to ask,
and will just write the previously entered focal length into the EXIF.
11-21-2014, 06:49 AM   #4
dakight's Avatar
I don't remember changing the SR setting, but it's possible since I've been playing with the settings and trying to learn the camera.
11-21-2014, 07:02 AM   #5
jatrax's Avatar
SR is also turned off if you set timed delay and some other shooting modes so no need to actually change the SR setting for this to happen.
11-21-2014, 07:27 AM   #6
schnitzer79's Avatar
whenever i attach on a manual lens, depending on what mode I have it (one of my user modes have SR off), i check the menu just to make sure.makes it easier for me later on when grouping my photos.
I had some dirty contacts once (i think thats what it was), and SR was ON but no focal length confirmation on startup.
11-21-2014, 07:40 AM   #7
dakight's Avatar
I wondered about dirty contacts. It's certainly possible because I bought the lens used and it has been stored until yesterday. It's asking everytime now
11-21-2014, 09:43 AM   #8
Is it on the 'a' aperture setting?
11-21-2014, 10:06 AM   #9
The SR setting is what gets saved in the EXIF, so that's strange!
There's an EXIF field called "35mm focal length", so perhaps you're misinterpreting that?
11-21-2014, 12:55 PM   #10
dakight's Avatar
That's entirely possible. I'm still feeling my way around.
11-21-2014, 01:18 PM   #11
It only asks for the focal length when the camera is turned on, though you can set it at any time.
11-21-2014, 02:31 PM   #12
ChristianRock's Avatar
Sometimes I'll turn on my camera and immediately do a half press of the shutter button to be able to use the green button for metering. As soon as you do that half-press, all options (including entering the FL for SR) are gone. It'll assume whatever was entered previously (or maybe 35mm is the factory default).
Also, if you don't enter a FL after a few seconds, the option also goes away and it sticks with whatever it had as default.
My guess is either you pressed the half shutter, or turned it on and didn't pay attention to the screen for a few seconds, and the option was gone.
50mm, course, k-30, k-50, lens, pentax k30, pentax k50
Auto focus question for K-50 Dewman Pentax K-30 & K-50 23 12-06-2014 07:47 PM
Using K Mount Manual Lens on K-30, K-50? Relativity Pentax K-30 & K-50 11 07-08-2014 04:05 PM
Another K-50 versus K-30 question seventysixersfan Pentax K-30 & K-50 25 12-23-2013 03:41 PM
K-50 focusing speed with DA 55-300mm and battery question Clarkey Pentax K-30 & K-50 3 09-08-2013 07:46 AM
Noob question: Should any K-mount AF lens work on K-01? harioharima Pentax K-01 3 02-12-2013 03:14 PM
All times are GMT -7. The time now is 03:17 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
