11-24-2014, 05:22 PM   #1
Shake reduction use with Hi continuous drive mode
I have noticed that, if I leave SR (Shake reduction) on in Hi continuous Drive mode, my pictures are blurry. If I turn off SR, the pictures are sharp. I believe the mirror slap is confusing/disturbing the shake reduction. Has anyone else noticed this? I have a Pentax K-50.
11-24-2014, 06:35 PM   #2
sergysergy's Avatar
are you panning? are you using a tripod?
11-24-2014, 06:40 PM   #3
I keep it off. SR is not something that should be left on, most of the time it can result in soft/blurry photos. I learned this with the K-7 during 2009.
SR is to help steady a shot that you're already trying hard to steady by hand. I won't help with camera motion in any other scenario.
11-24-2014, 07:54 PM   #4
sergy,
No panning. Not on tripod. Just sitting in a chair holding the camera by hand as steady as possible...
11-24-2014, 08:14 PM   #5
QuoteOriginally posted by Steve.Ledger Quote
The K-7 had a particular and documented problem with that for specific shutter speeds, but it isn't really a general problem. "Most of the time" is a major over statement. It DOES help if you use it properly.
As far as the problem the poster is having, I'm not sure. Sometimes I turn on continuous drive (usually low, however) in order to help get sharper shots (the 2 or 3 shot is often sharper than the first), I'll be curious to do some tests with Hi mode on the K-5...
11-24-2014, 08:44 PM   #6
I noticed this by accident the other day. I rarely use continuous (hi or lo) drive mode since I am a studio portrait photographer. I assumed that, for most shooting handheld, SR should be on to minimize camera shake. I guess this is not the case.
continuous drive mode, drive, k-30, k-50, mirror slap, mode, pentax k30, pentax k50, pictures, reduction, shake, shake reduction, sr
Shake Reduction Not An Option in Movie Mode noroadsexpeditions Pentax K-30 & K-50 3 04-11-2013 06:28 PM
no shake reduction in video mode skipdc Pentax Q 2 02-24-2013 02:58 PM
Shake Reduction and Av mode Chaim Pentax K-30 & K-50 20 01-08-2013 01:52 PM
[k-x]How to enable shake reduction in video mode with manual lens? tiny Pentax DSLR Discussion 9 03-15-2010 07:56 PM
AF-540 FGZ with drive mode/continuous shooting. MRBHV Pentax Camera and Field Accessories 2 02-26-2009 06:40 PM
All times are GMT -7. The time now is 03:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
