11-27-2014, 07:18 AM   #1
SR not highlighted in info mode
I cant seem to select the SR feature on my K-50. When I press the info button it will not allow me to select the SR feature. I am using the standard kit 15-55 WR lens. I could find no information on how to set the SR feature other than through the info button selection process.
Thanks for the responses in advance.
Mike
11-27-2014, 07:30 AM   #2
jatrax's Avatar
What shooting mode are you in? SR is disabled when the timer is on, and in some other modes like bracketing.
11-27-2014, 07:36 AM   #3
I am shooting in manual mode with auto iso set from 100-1600 and live view selected. I have tried in P Mode also and cannot select the SR feature.
Thanks for responding.
Mike
11-27-2014, 08:07 AM   #4
Make sure your in Single Frame Shooting or Continuous Shooting mode (use the four-way controller). If you're in one of the self-timer modes (2 sec or 12 sec) or the remote control mode, shake reduction is disabled as it's believed you're using a tripod where shake reduction should be disabled.
11-27-2014, 08:29 AM   #5
jatrax's Avatar
QuoteOriginally posted by stilabel2 Quote
Mike
Those are exposure modes not shooting modes. Make sure you are shooting in single frame mode not timer or bracketing.
11-27-2014, 10:04 AM   #6
dakight's Avatar
SR on or off is in the First set of menus, menu #3. If self timer or some other modes are selected it will be disabled. Be sure you're in single frame mode, press the menu button once then tab over to menu 3; it is near the bottom.
11-27-2014, 10:46 AM   #7
I am in SFM no timer and no bracketing set but still no SR activation allowed (grayed out) and cannot select.
---------- Post added 11-27-14 at 09:48 AM ----------
I have tried the info button but it will not let me select SR. I am at the point of doing a complete reset and then add one menu item at a time to determine what is blocking the feature.
Thanks for all the input but if anyone has a faster method I will certainly try it.
Mike
---------- Post added 11-27-14 at 10:05 AM ----------
Thanks to everyone that responded. I did what I have done with other cameras in the past with a complete reset and then added features back one at a time. After doing that the SR feature now functions as advertised. I will probably turn this off unless I am using shutter speeds below a 60th depending on lens in use. I really appreciate the help on this one. Happy Thanksgiving to all hands and a Happy & safe holiday season.
Mike
11-27-2014, 11:54 AM   #8
There are a couple of other situations where SR is deactivated -- using HDR and Composition Adjustment. Also, if you're using a manual focus lens and don't have the focal length set, SR will be disabled. If none of this is an issue, a reset may be necessary, but you might just want to try removing the battery and then reinserting it before resetting.
button, feature, info, k-30, k-50, mike, pentax k30, pentax k50, post, reset, sr, thanks, time
Do you turn of SR in continuous mode? adwb Photographic Technique 9 07-08-2014 07:56 PM
Q: Hide settings info in shooting mode rfc1925 Pentax Q 7 10-20-2013 06:08 PM
istD (not ds) - no exposure info in vf with m42 Steve Beswick Pentax DSLR Discussion 2 04-09-2013 10:45 AM
Why is SR disabled in wireless flash mode? panoguy Flashes, Lighting, and Studio 6 04-04-2009 04:43 AM
SR Disabled in Wireless Flash Mode? Old Timer 56 Pentax DSLR Discussion 5 01-06-2008 10:02 AM
All times are GMT -7. The time now is 12:06 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
