12-06-2014, 06:11 AM   #1
Michi Joel's Avatar
I come from the K-5 and i want to set K-50... help
I come from the K-5 and desire the following, set the K-50 so that when you turn not miss the following configurations:
- The display is turned off unless I turn it on.
- The ISO is not automatic, either 100 or what I decide.
- May you always be behind the wheel aperture and the front is the speed.
I do not find in the manual as I can change all this, anyone can help me?
Unless this is a fantastic camera, if I had 80 ISO ...
tnx so much
12-06-2014, 06:45 AM   #2
FantasticMrFox's Avatar
That should pretty much be the automatic settings. If you turn off the display and switch the camera off, the display should stay off when you switch the camera on again. Same with ISO, if you don't specifically set it to AUTO ISO, AUTO ISO won't be on. Don't know about the control wheels though.
Which mode are you shooting in?
12-06-2014, 06:56 AM   #3
Michi Joel's Avatar
QuoteOriginally posted by FantasticMrFox Quote
Tnx for your response.
I shoot normaly in manual mode and aperture priority, if i turn off the camera doesn't respect my settings.
12-06-2014, 07:11 AM   #4
QuoteOriginally posted by towa Quote
You could make a User mode, here's a recipe for that:
https://www.pentaxforums.com/forums/151-pentax-k-30-k-50/231840-turning-off-k...d-display.html
Should work for both the screen, ISO and control wheel settings.
12-06-2014, 07:22 AM   #5
Michi Joel's Avatar
Tnx so much, i'll try it!
12-06-2014, 08:24 AM   #6
AquaDome's Avatar
tnx so much
You cannot can swap the wheels on the K-50. I also like Aperture in front, Shutter in rear. You can do this on the K-3.
12-06-2014, 08:39 AM   #7
I confirm that if you turn off the LCD screen in the K50 it only persists until you turn it off. When you turn the camera back on, the screen is back. So you'd have to do it every single time. Gets annoying really quickly.
12-06-2014, 08:43 AM   #8
Michi Joel's Avatar
tnx guys. I haven't tha k-50 with me right now
12-06-2014, 08:52 AM - 1 Like   #9
I have K-50 and the dials can be swapped.
I have aperture in front / shutter on the rear side. I keep it like this because the only thing one needs to change real-quick is shutter - having it on the rear side makes it easy to change shutter speed with thumb finger and keep the pointing finger on the release button.
Go to MENU -> 4th page for shooting settings -> E-Dial Programming
Here you can choose the functionality for the dials in each shooting mode (M,P,Av,Sv etc.) I did it for all such that I don't get confused.
Good luck, it's quite intuitive.
12-06-2014, 09:06 AM   #10
Also, check the Memory sub-menu...
12-06-2014, 09:13 AM - 1 Like   #11
AquaDome's Avatar
QuoteOriginally posted by misomosi Quote
I am looking now and see that it is where you say it is. Was this added with a newer firmware version? I don't think I ever checked after updating.
12-06-2014, 09:42 AM - 1 Like   #12
You can turn off the rear display and keep it off even when you turn the camera on again. Look at page 217 of the owners manual regarding Memory settings. If you check the Display box under Memory in the Menu, the camera will return to how it was when you shut off the camera. If the screen display was on when the camera was shut off, the display will be on when you turn the camera on. If the display is off, it will be off when you restart the camera.
12-06-2014, 10:40 AM   #13
Michi Joel's Avatar
QuoteOriginally posted by T Evergreen Quote
Truth! tnx so much!!
---------- Post added 12-06-14 at 06:45 PM ----------
Truth! tnx for your answer!
K-50 is an amazing camera for the prize ^^
12-06-2014, 04:55 PM   #14
QuoteOriginally posted by AquaDome Quote
I have v1.00
I didn't know there was a newer firmware version. I'll go check
camera, change, dials, display, finger, iso, k-30, k-5, k-50, memory, menu, page, pentax k30, pentax k50, shutter
Any NYC-area K-3 owners want to come out and play? frogoutofwater Pentax K-3 11 12-03-2013 06:30 PM
New Firmware for K-500, K-50, K-5 II, K-5 IIs, K-5, K-30, K-01, K-r, and 645D is out Adam Pentax News and Rumors 60 09-16-2013 05:46 AM
Please help, i am about to buy a k-30 and i need some advice (mabe a lot). carlosodze Pentax K-30 & K-50 15 05-20-2013 11:11 PM
I'm waiting for my K-30 to come in mail. Did I get the WR 18-55mm lens?? spectamaniac Pentax K-30 & K-50 4 02-15-2013 03:42 AM
Hrm ... How do I set the K-5 to ISO 80?! Tord Pentax K-5 10 02-05-2011 10:47 AM
All times are GMT -7. The time now is 05:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
