Originally posted by Des
I haven't had that experience with my K-30+DFA 100 WR Macro. I suppose you could deal with this in several ways:
- use spot metering and meter for the highlights in very bright conditions
- use a neutral density filter
- use exposure compensation.
I should have added that often, I only have a few seconds to get my shot. I don't have a lot of time to fiddle with different options/filters/etc. If I did, I'd just shoot manual. With my K30, I find TAV
mode works well. Perhaps a combination of exposure compensation and bracketing might be an option ( ie. set moderate compensation, and then apply bracketing to account for when more or less
compensation is needed ). The downside is that this would result in lots of extra exposures, but I guess I could only use compensation+bracketing when I anticipated having problems.
To complete the settings test, you might also try various settings for shadow correction (it can affect exposure by up to 3 stops).
I may be mis-remembering, but I was under the impression that it's only the highlight correction that changes the actual exposure, while shadow correction does not.
Just thinking aloud - I have noticed that sometimes when I first mount a lens it produces overexposure. I wonder whether it could be a little condensation on the front or rear element, or whether the aperture blades might not be moving freely?
That's a possibility, but if that was the case, one would expect it to manifest itself on my K200D as well.
