12-08-2014, 11:35 AM   #1
self made strap lug
neck strap, attached by usual way was not comfort for me.
I need neck strap attached at left side of camera.
so, I make strap lug from paper clip (steel nickel-plated wire 1.6 mm OD), and attach it to the grip body at the left.
now right side of the camera is free of strap, so it does not disturb me then I shoot portrait.
PENTAX Q  Photo
12-08-2014, 11:47 AM   #2
johnmflores's Avatar
Cool! How'd you attach the paper clip to the grip?
12-08-2014, 11:48 AM   #3
That's very neat. Just make sure it is strong enough!
12-08-2014, 12:18 PM   #4
QuoteOriginally posted by pentajazzz Quote
Sorry, I would not trust my camera to a paperclip. I have been doing mechanic work and metalworking all my adult life. One thing I know, paperclips are some of the worst Metal available. if you want to make a strap lug for your camera, use a better piece of metal. drill rod, 01 or A2. And harden it. But not a paperclip, And Not on my camera.
Also, although there are some very good plastics these days, some of which are approaching the strength of metal, I would not trust my camera strap when it was connected to a piece of plastic. I would want something more substantial. the plastic was never designed to hold a lug at that point. I think more of my equipment than that. I Would rather put up with a little bit of inconvenience, for better security.
12-08-2014, 01:05 PM   #5
original lugs has a 1.5 square mm section cut (1x1.5 mm), and 1.6mm OD steel wire has a 2 square mm section cut.
so, paper clip is factor x1.7 stronger, than original lugs (ha-ha) (strengths has a quadratic dependence of section cut)
Yes, this steel rod possibly soften, than original lugs, so let's thing it is AS strong AS original lugs.
so, lets think, that this wire NOT from the paper clip, but regular nickel plated steel.
sounds more better?
used this kind of clip, but bigger one
http://myoasisofficesupplies.com/test/productimages/double-clip-15mm-small-.jpg
wire was bent as П shape and inserted in to drilled holes.
after that ends of П shape was bent as C shape, bur square, and hot-embossed in to plastic of grip body. some CA glue added and upper plate of grip returned.
upper plate make impossible to disassembling of lug.
it is really strong and tested.
(attached picture shows C-bend of steel wire)
QuoteOriginally posted by promacjoe Quote
I never trust, I'm always check.
---------- Post added 12-08-14 at 11:08 PM ----------
QuoteOriginally posted by sergysergy Quote
it DOES hold 18 kilograms. (18 liters of water)
I will never test it until it breaks, because I have only one, but it really strong.
---------- Post added 12-08-14 at 11:12 PM ----------
1.6mm OD, 4 times, 90 degrees, 1mm bend radius bent, 45mm long, drill rod?
that's sounds funny!
---------- Post added 12-08-14 at 11:13 PM ----------
I never forse anybody to do something with his own equipment, it is up to him.
12-08-2014, 01:18 PM   #6
narual's Avatar
That's not a paperclip. It's a binder clip. Huge difference.
Binder clip - Wikipedia, the free encyclopedia
Paper clip - Wikipedia, the free encyclopedia
12-08-2014, 01:30 PM   #7
QuoteOriginally posted by narual Quote
You caught me!
excuse me for my French, but
http://myoasisofficesupplies.com/test/productdetails.php?catid=7
next time I will use only "regular nickel plated steel wire"
12-08-2014, 03:40 PM   #8
Now you know why i was so surprised when you said you used a paperclip. what you used was equivalent to what I suggested. just because two pieces of metal are the same thickness, it doesn't mean they have the same strength.
12-08-2014, 03:51 PM   #9
OrangeKx's Avatar
Nice.
12-09-2014, 01:15 AM   #10
sure, but... even SO big paper clip will be also good.
I cat test it, if I will find one so big
12-09-2014, 09:43 AM   #11
narual's Avatar
I don't think you'll have much luck. Paperclips are intended to be fairly flexible, and they're typically poor quality metal that breaks easily. I used to break them all the time while being stuck on conference calls, just for something to do with my hands.
12-09-2014, 09:52 AM   #12
LFLee's Avatar
hold on.... that looks like a K-30 or K-50, where did the battery grip come from?
.... what is that huge view finder you got there??? o_0
12-09-2014, 11:50 AM   #13
Drill rod, 01 and A2 are materials that have high strength when the forces are parallel to length of the material. The are very brittle when subjected to side forces and even more so when heat treated. Just think about that .030 diameter drill bit that you accidentally snap when drilling with a hand drill.
12-09-2014, 12:59 PM   #14
QuoteOriginally posted by LFLee Quote
Grip for K-30 - I make it by myself from K-7 grip. (also see my signature below post )
it has D-Li109/D-Li90 or 4-to-6 AA compatibility (3 type of battery,yahhh )
but to be honest - I'm not using AA, only lithium.
also grip has a shutter button.
see the link below
https://www.pentaxforums.com/forums/151-pentax-k-30-k-50/216730-battery-grip-...ml#post2507501
https://www.pentaxforums.com/forums/151-pentax-k-30-k-50/216730-battery-grip-...ml#post2700957
TENPA 1.36 magnifier, must have.
camera, clip, drill, k-30, k-50, mm, neck, pentax k30, pentax k50, pm, rod, section, shape, square, steel, trust, wire
self made optical viewfinder for Q pentajazzz Pentax Q 17 12-11-2015 08:17 AM
Epic Self-Promotion: Photographer Has 400 Action Figures of Himself Made interested_observer Photographic Industry and Professionals 8 11-24-2013 06:41 AM
Loose strap lug on SP revdocjim Pentax Film SLR Discussion 3 05-22-2012 10:13 AM
K7 Strap lug problem nakey Pentax DSLR Discussion 23 04-19-2010 06:03 PM
Spotmatic II loose strap lug question Steve Beswick Pentax Film SLR Discussion 4 11-20-2009 10:23 AM
All times are GMT -7. The time now is 05:03 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
