12-12-2014, 01:51 AM   #16
@xinaesthetic I actually have the exact same equipment as you do... K30, cheap AA adapter, bc700 charger, and I use eneloops. The ones I got were said to be precharged so I just stuck them into the camera and had some issues. The camera wouldn't wake up from "slumber mode". Opening up the battery door and pressing the adapter back into place always got it working again. When I got around to charging the batteries (one of the four wasn't charged...) everything went to the way it should. Now I get lots of shots out of my eneloops and as for the adapter.. As long as you handle it with care I agree with everyone else here. The original Pentax adapter just doesn't justify its price for what it does.. But I'd you're more rough with your equipment, the investment might be worthwhile (and more environment-friendly too as you've noticed).
12-12-2014, 10:52 AM   #17
I've had zero issues with the 1 cheap AA adapter I've possessed since the K-30 came out, Eneloops gave me over 1000 shots on one test but more on that later, and DSTE Li-Ions are really good for cheap replacements - better than other (no-name) eBay cheapies I've tried and they measure almost the same capacity in mAh as the Pentax OEM.
All NiMh rechargeables, Eneloop low self discharge as well as the normal type, when freshly charged (in a decent charger) will have a terminal voltage in the region of 1.45v or so. Your K-30 will love 4x1.45v but won't operate below roughly 4x1.18v. If you just fire off one shot after the other just after a charge then you may well get the 1000 shots I achieved, but if you leave NiMh batteries for a couple of weeks (even Eneloops) their terminal voltage will sag somewhat, perhaps to something nearer 1.36v. Their mAh capacity won't have dropped much though, at least with Eneloops and their LSD brethren. You won't get as many shots though, perhaps 4-500 as the camera only responds to terminal voltage and shuts down below approx 4.7v total, and it will get there sooner from 4x1.36v than it will 4x1.45v. So basically, Eneloops last longer than others over a period but they still like a top-up before a heavy shooting session.
adapter, batteries, battery adapter, bit, charger, k-30, k-50, k30, pentax, pentax k30, pentax k50
Will the k-3 take the AA battery adapter or do I need to purchase a battery grip Sorver Pentax K-3 8 12-12-2014 01:08 AM
AA Battery Adaptor for K30 woonona_butch Pentax Camera and Field Accessories 13 07-28-2013 05:37 PM
why no AA battery adapter for K-7? Loren E Pentax Camera and Field Accessories 10 03-02-2011 11:57 AM
Anyone found the optional AA battery adapter for... sredd68 Pentax Camera and Field Accessories 23 01-23-2011 03:15 PM
All times are GMT -7. The time now is 03:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
