12-18-2014, 10:11 PM   #1
lens clean and lens filter
Hi there, my pentax k 50 lense got haze stain, which requires wet clean. I've googled it and read some posts on forums, and most users recommend the ROR Residual Oil Remover, Purosol Optical Cleaner, or eclipe cleaner, with Tiffen Lens Cleaning Paper. The other alternative is to use Zeiss Lens Wipes. Can anyone who ever used thesed products recommend the best one, the one leaves no residue or treak and most importantly no scratches? After cleaning, I want to buy a lens filter to protect the lens, do you have any recommendation of the affordable good filter under 50 bucks? Thanks!
12-19-2014, 07:28 AM   #2
QuoteOriginally posted by kittycd Quote
I've used Zeiss Lens wipes on my filters when needed in the field but would not do so with my lenses. Purosol or ROR is fine but use a cleaning cloth (never paper) on your lenses. Since I wear glasses, I use cleaning clothes
from Lens Crafters. A bit more expensive maybe but it will not scratch you filters or lenses. Also they can be reused if necessary once they dry. In terms of a low priced clear or UV filter, I would advise B+W, Hoya, Marumi but remember that you get what you pay for. I've used Tiffen as well I've seen some loss of sharpness and they are a pain to clean. Whatever you get make sure it has some type of MRC coating which cleans up easily enough without streaking. I am in midst of trying Pro Optics from Adorama and all reviews seem postiive and low cost.
Best of Luck!
12-19-2014, 08:58 AM   #3
QuoteOriginally posted by eminker Quote
Best of Luck!
Thanks a lot
filter, k-30, k-50, lens, paper, pentax k30, pentax k50
How you clean the Canon Mark 2 sensor and the lens interested_observer Non-Pentax Cameras: Canon, Nikon, etc. 8 08-08-2014 09:54 AM
pentax 35mm DA 2.4 lens hood and filter mellowyeahlow Pentax SLR Lens Discussion 16 07-09-2014 07:24 AM
Lens polarizing Filter for 15mm limited and 18-135 Skipper74 Pentax K-5 3 01-05-2013 10:13 PM
Soft focus with vaseline and a filter, how to clean filter? Metalwizards Photographic Technique 13 04-24-2012 12:50 AM
How to best clean and repair old lens & bodies? hinman Pentax DSLR Discussion 14 12-21-2007 05:22 PM
All times are GMT -7. The time now is 01:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
