12-25-2014, 09:28 PM   #1
tabl10s's Avatar
K-30 Won't Power-up With Eneloops.
Inserted with re-charged batteries and the LCD screen turned different colors while changing the date/time, etc. The camera works fine with the Li-On.
12-25-2014, 09:51 PM   #2
EarlVonTapia's Avatar
I find that with the AA adapter, sometimes the battery connection isn't as solid as with the regular battery, so when I jiggle the camera around it intermittently loses power. Perhaps that's the cause of it?
12-26-2014, 01:53 AM   #3
Not a Number's Avatar
Have you tried setting the battery type in the setup menu?
12-26-2014, 08:26 AM   #4
I have a cheap Chinese knock-off AA adapter and it was a little finicky. The battery tabs aren't springy enough and two of my batteries aren't held in. I have to bend the negative terminal tab upward with a screw driver. After that the battery and terminal made better contact and it's been working like a champ. I notice that the battery levels are not always properly reported. The battery icon can go from full to empty in a few minutes. My K-30 can still fire off a good day's worth of shots with the battery icon at empty. Maybe the batteries provide enough current but too low of a voltage? I don't know. It works.
12-26-2014, 12:22 PM   #5
tabl10s's Avatar
It's set to "Auto Detect".
12-26-2014, 12:26 PM   #6
QuoteOriginally posted by EarlVonTapia Quote
There are 10 connections in series, all it takes is one or more to not connect properly at the high burst current a DSLR can take and not enough voltage gets through for the camera to work properly. A tiny drop of protective switch cleaner on each contact can work wonders.
12-26-2014, 12:32 PM   #7
QuoteOriginally posted by tabl10s Quote
It may not be auto detecting properly. Try setting it to NiMH.
02-08-2015, 09:53 PM   #8
Aaron28's Avatar
have the cheapie 'aa' adapter and it does not like my duracel rechargeables unless fresh out of the charger any time after that I get 'battery depleted'......they are a few years old and are used by numerous gadgets........but if I pop in some cheap alkaline they work fine.....
02-08-2015, 10:04 PM   #9
NiMH batteries have a slightly lower inherent voltage. I suspect if you are inserting rechargeables straight from a recharging cycle they are temporarily sitting at a higher voltage and confusing the battery autodetect as to what battery type they are. Once out of the charger for a while, battery voltage settles down but by now the autodetect is confused and thinks the voltage drops equates to a flattening battery. Suggest you take camera off autodetect and set it to NiMH.
02-09-2015, 08:21 AM   #10
tabl10s's Avatar
QuoteOriginally posted by southlander Quote
I'll try that.
Thanks.
k-30, k-30 won't power-up, k-50, pentax k30, pentax k50
*ist DL won't power up uicguy Pentax DSLR Discussion 26 07-24-2017 11:53 AM
K-30 shutter won't release siniharakka Troubleshooting and Beginner Help 3 07-18-2014 05:59 AM
K-30 Won't Turn Off g026r Troubleshooting and Beginner Help 17 02-04-2014 03:13 PM
K-30 won't select SR cali92rs Pentax K-30 & K-50 6 07-06-2013 06:36 AM
K100D firmware update - now won't power up bjcwheeler Pentax DSLR Discussion 6 04-26-2012 04:10 PM
All times are GMT -7. The time now is 02:13 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
