Originally posted by focusr3 I bought the 2 lens kit But if i could do it again i wouldn't have. I would recommend the 18-135 kit. It gives you more range with out swapping lenses the point in WR is to stay that way if you are in the elements the last thing you want to do is swap lenses. The 18-135 mm also seems to be more highly regarded.
I 100% agree with this. I started out with a K-30 & 18-55mm WR kit. While the 18-55mm WR lens is solid, the 18-135mm WR is a huge improvement and that extra reach is more than worth the extra cost. I eventually sold both and bought a K-5ii w/ 18-135mm WR.
I know it's more money but I definitely recommend you spring for the 18-135mm WR lens instead of the 18-55mm. 55mm will only take you so far and as others have said, switching lenses just to get the extra reach is a pain, and using a non WR lens to boot sort of defeats the whole purpose of the versatility of the weather sealed body.
