04-13-2015, 11:45 AM   #1
K-50 Rear e-dial jam (Av mode)?
Hey,
Recently noticed following flaw in my K-50:
When I shoot in aperture priority mode (Av), with rear e-dial for aperture setting, I noticed that sometimes after photo taken. the aperture size value stucks in one position despite rear e-dial rotated to change other f value. To overcome this I have to push INFO or MENU button twice to reset and everything is fine then.
Is it just some firmware flaw or should I contact service because something is wrong with my camera?
Greets
04-13-2015, 05:33 PM   #2
dakight's Avatar
I would suggest doing a reset and see if it doesn't clear the problem. Otherwise if it's in warranty I would probably send it in.
04-13-2015, 09:04 PM   #3
QuoteOriginally posted by dakight Quote
Do you mean reset - p. 219 in manual?
04-14-2015, 12:14 AM   #4
I notice the same thing in BOTH my K30's as well. I never thought anything was actually wrong other than just a small glitch in the wheel.
Have noticed it in other applications using the rear wheel also other than Av mode. Its almost like its temporarily dead during use. I just give it a second and try again....it always works.
Don't know whats wrong , but since it always catches up and works a second later just fine I don't worry at all about it. One K30 has 53K clicks and the other about 4K....I just keep shooting !
Don't know if this the same problem ? Like the wheel just doesn't notice its getting turned at all and sits there ? I need to check , but believe if I press the shutter part way and then rotate its cleared....will have to double check.
One thing for sure , it only does it for a few seconds and always clears quickly on its own without pressing menu or info. On mine its just a minor irritant from time to time and I end up wondering why it glitches again ? I believe turning the wheel fast may have something to do with it also , as when I turn it slowly/deliberately it seems to not happen at all.....just my observation from memory.
04-14-2015, 01:13 AM   #5
dakight's Avatar
QuoteOriginally posted by ps1984 Quote
I don't have the manual handy but it 's on Menu - Tools - 3 - Reset.
aperture, e-dial, e-dial jam av, flaw, k-30, k-50, k-50 rear e-dial, pentax k30, pentax k50, value
Rear E-Dial Wouldn’t Dial. This Ever Happen to You? veezchick Troubleshooting and Beginner Help 15 11-04-2014 08:50 PM
K-50 Noisy Front E-Dial suzook600 Pentax K-30 & K-50 4 02-17-2014 05:28 PM
K-30: Lost Manual Mode on E-Dial knightzerox Pentax K-30 & K-50 7 12-06-2013 11:31 PM
P mode; what's the difference between E-Dial set to P Shift or to Av? Sunday Troubleshooting and Beginner Help 9 07-08-2011 06:53 AM
K-7:Rear e-dial not working correctly bulacawa Pentax DSLR Discussion 11 05-29-2010 04:13 AM
All times are GMT -7. The time now is 03:23 PM. | See also: NikonForums.com, part of our network of photo forums!
