05-11-2015, 05:19 PM   #1
Focal length info on playback accuracy
I'm interested in some new lenses so I'm playing around with my 18-135mm, taking shots at different focal lengths to see if I like the working distance, FOV, etc. However, I'm noticing that using the distance scales on the lens doesn't necessarily translate to the focal length reported by the info on the playback screen. Seems like it's rounding off to certain values.
For instance, I'm trying to shoot at 77mm. There is a 70mm marking so I go a little beyond that. I take a picture and check the info, it states 78mm. So I make a minute adjustment and shoot again. Upon review, it's still 78mm. I keep going further and it still reports 78mm until I go so far that it has to jump to another number (60-something, IIRC). But anywhere around the 70mm area, it reports 78mm.
Is there a reason for this? I haven't offloaded those images and checked the exif data on the computer. But I would like to know why the on-camera info doesn't correspond with the focal length markings on the lens.
05-11-2015, 05:29 PM   #2
QuoteOriginally posted by Zerv Quote
I'm interesting in some new lenses so I'm playing around with my 18-135mm, taking shots at different focal lengths to see if I like the working distance, FOV, etc. However, I'm noticing that using the distance scales on the lens doesn't necessarily translate to the focal length reported by the info on the playback screen. Seems like it's rounding off to certain values.
There are breakpoints on the data that the lens reports back to the camera. Whatever you see in playback mode is what the camera was told by the lens, and there is certainly some wiggle room.
05-11-2015, 10:11 PM   #3
sterretje's Avatar
Live with it DA55-300 behaves similar (at least at the long end).
That will not make a difference; the info in the review/playback is extracted from the EXIF.
70mm, distance, info, info on playback, k-30, k-50, length, length info, lens, pentax k30, pentax k50, playback, reports
Rokinon 14mm setup on K-3? Focal Length? uday029 Pentax SLR Lens Discussion 11 12-15-2014 08:50 PM
FA 31mm Ltd. on K-3: Focal length disappears on LCD Ztrejfer Pentax SLR Lens Discussion 3 04-15-2014 07:54 AM
Focal length for manual zoom on K-5 prepelica Pentax K-5 13 10-31-2013 03:40 PM
What does the DSLR do with the focal length info when using MF lenses? Ari Freund Pentax DSLR Discussion 15 02-25-2010 07:38 AM
Focal length info. pcarfan Photographic Technique 6 09-23-2007 08:23 AM
All times are GMT -7. The time now is 08:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
