Show Printable Version 16 Likes Search this Thread
05-14-2015, 03:08 PM   #1
K30 Low light performance
Am I the only one who finds that the K30 low light performance is really bad?
I get extreme amounts of noise starting at 32,000 ISO. Most indoor scenarios when I am looking to take photos, it always needs 32,000 ISO or more and can't get faster than 1/40.
Anyone got some tips or tricks for shooting in low light without having to resort to the flash on the camera?
I'm assuming lens with high f-stop would help? But seems like anything with good f-stop is pricey.
05-14-2015, 03:24 PM - 1 Like   #2
EarlVonTapia's Avatar
QuoteOriginally posted by mellowyeahlow Quote
Tripod
Fast lens - Fast 50mm's are quite cheap, and can help you get those low-light shots you need.
Steady hand
It's also quite amazing how much detail you can rescue from the shadows in a RAW file. A picture might look dark on your LCD, but try and see what you can do with it through post-processing.
Also, I've found the shake reduction to be quite good. After some practice, I can usually get good shots at 1/20 if needed.
05-14-2015, 03:27 PM - 1 Like   #3
jimr-pdx's Avatar
Wow, if iso 32k is what you need that is going to be tough for nearly any camera. A 24 or 28mm f2.8 will help at a fairly low price point but a 3.5-5.6 zoom will not be your best option. Can any other ambient light be added to the room?
05-14-2015, 03:28 PM - 1 Like   #4
I actually find the low light performance of the K-30 to be quite good - certainly a step up from my K-x (which was also quite good)!
I shoot up to iso 800 without second thought, don't mind using up to 3200 on a regular basis, and can get some usable results from 6400 (with noise reduction in post-processing).
As you said, it helps to use lenses with a large maximum aperture (f2.8 or less), as small f-stops mean that the lens lets in a lot of light.
Fellow PF member Heie has written a useful guide on holding the camera steady for long exposures: Making the Most of Long Exposure Handhelds - Introduction - In-Depth Articles
05-14-2015, 03:56 PM   #5
virusn3t's Avatar
How can you got 32k ISO? My K-30 only reach 12.8k ISO, maybe 25.6k with expanded sensibility...
I like the performance up to 4k
05-14-2015, 04:04 PM - 1 Like   #6
clockworkrat's Avatar
I'm pretty content with it so far. The sensor-based SR and decent high-ISO performance make a good team.
05-14-2015, 04:16 PM - 1 Like   #7
richandfleur's Avatar
Probably. It's the same classic sensor as the K-5 era cameras, and they're all pretty well regarded in the APS-C world.
There's your problem then. I don't shoot about 1,600 on my K-30 normally, but will push to 3,200 if required to get the shot, and only higher if it's absolutely necessary.
Whilst the dial allows you to set higher ISO figures, they're close to worthless in reality.
Across the board there has been a big push for high Mega Pixel count cameras/sensors, often at the expense of noise/high ISO capabilities.
Agree there are times where you can't control the lighting, flash isn't allowed or isn't suitable, and where some decent ISO ability would be really handy.
Maintaining a fast shutter speed to freeze motion is not easy if you haven't got enough light to play with.
What subject matter/location are you trying to shoot?
Do you have any control over lighting levels at all?
Can you shoot earlier in the day for instance, where applicable?
Shooting with a wide aperture / lower f values, say f1.8 - f4 for instance, opens up the lens and lets in as much light as possible.
It will reduce your depth of field though, so getting focus correct is very important at these wide apertures.
Keep your shutter speed as low as possible, to gather more light.
This doesn't work so well if there is any movement, unless you're going for that effect. Keep the camera steady if there is no movement in the shot, using a tripod or a monopod for support etc.
Yes basically after doing all you can on camera you will need to introduce some more light to play with, and flash seems the most obvious way to do this.
So, if it's suitable use the on camera flash or use one or more off camera flashes.
Wait and buy the new FF camera, as hopefully this will have better low ISO
05-14-2015, 04:19 PM - 1 Like   #8
I think for the most part, it's a question of mastering the technique. Around ISO 3200 the K-30 does exhibit a noticeable amount of noise, but you should still be able to get excellent images for web and print use.
First of all, are you shooting in RAW? Feel free to post samples of results you're dissatisfied with and we'll take a look.
05-14-2015, 05:14 PM - 1 Like   #9
Oldbayrunner's Avatar
Are you selecting 32,000 or is your camera auto selecting? I don't know of too many crop sensor cameras that won't exhibit a good amount of noise at that high ISO. Try limiting your ISO range lower.
05-14-2015, 05:15 PM - 1 Like   #10
Agree, and what is the OP's approach to dealing with the noise in post also?
05-14-2015, 05:57 PM - 1 Like   #11
stillshot2's Avatar
I think the OP meant iso 3200, but either way, show us some pics or we can't help! I don't mind using iso 3200, but I do post process the RAW file afterwards.
05-14-2015, 06:10 PM - 1 Like   #12
hcc
hcc's Avatar
Am I the only one who finds that the K30 low light performance is really bad? Most indoor scenarios when I am looking to take photos, it always needs 32,000 ISO or more and can't get faster than 1/40. .
As indicated by others, the K-30 has a decent sensor and should be a good performer in low light. But you need to mount a fast lens to get good performances in very low light.
What lens do you use? Your kit lens?
In low (to very low) light, you need to use a fast lens: f1.8, f1.4 or even f1.2. This is a necessity.
Let me share a personal experience with my old K-7. The K-7 is well-known to be quite bad at high ISO. Anything above ISO 800. I was shooting many years ago with my K-7 together with a friend who had a FF Nikon with a zoom lens (f2.8 possibly, but most likely f4). We were outdoor and it was sunset. About 19:00, I had to stop shooting with my zoom and I replaced it with my VL58mm f1.4. At 19:15, my friend stopped to shoot with his Nikon FF. I was able to shoot with my old K-7 + fast prime until 19:45 when I went home. And I had decent shots....
Simply a fast lens (ie a fast prime) is a must in low light.
05-14-2015, 07:04 PM - 1 Like   #13
As above though, it may not be suitable for the shot you had in mind, as in f1.4 is going to give a narrow depth of field, unless you're back far enough that the subject is past the infinity setting of the lens.
Overall better ISO / low noise ability is something I'd really want in a camera, more so than an ever increasing MP count. You have to be bold to achieve it though, such as Sony's A7s camera.
05-14-2015, 09:02 PM - 1 Like   #14
rfg
QuoteOriginally posted by stillshot2 Quote
I think the OP meant iso 3200 ...
Yes assume so
To the OP, how are you viewing your photos? If 1:1 then you will see noticeable noise with any crop sensor camera at 3,200. Most of the images posted here are down-sampled to ~1024 pixels on the long edge, and certainly there are a bunch of very nice high iso examples from the K30 in the image thread. Or use the sample photo search tool and select K30 and 3,200 iso. Do you get similar results to these?
05-14-2015, 09:08 PM - 1 Like   #15
Kozlok's Avatar
For ISO 3200, you need software for noise reduction. Shoot in Raw, adjust the luminance noise slider.
Do consider a fast lens. The Sigma 30mm/1.4 is an excellent indoor choice. Shoot it at f2, and it's quite great, and probably 2 full stops faster than your zoom. Any 50mm 1.7 or 1.4 is also great.
f-stop, iso, k-30, k-50, k30, k30 low light, light, pentax k30, pentax k50, performance
Question about 6MP bodies and low light performance Darley Pentax DSLR Discussion 82 11-16-2013 02:18 PM
DA 17-70 low light performance sany Pentax SLR Lens Discussion 2 08-09-2011 07:39 PM
K200D low light/high iso performance indytax Pentax DSLR Discussion 22 02-07-2009 07:49 PM
K20D low-light performance Stoosh Pentax DSLR Discussion 10 03-03-2008 03:44 AM
A Low-Light Performance paden501 Post Your Photos! 3 01-29-2008 12:18 PM
All times are GMT -7. The time now is 06:01 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
