Originally posted by azappraiser I was looking at this same one for my K-50... does it allow for a tripod quick release plate to be mounted on the bottom while attached to the camera?
Its design does allow for it, but after trying it a couple of times, I gave up on using it with a tripod. Instead, I disconnect the hand strap from the bottom of the camera and mount the camera directly to the tripod plate. There are three problems with trying to use the tripod mount on the hand strap: the camera is mounted with the lens off center relative to the tripod center; the strap's base plate, while plenty solid/beefy for use as a hand strap, flexes too much for tripod use; the base nut is press fit into the hand strap base and starts to pull out. Bottom line, the thought was nice, but it is effectively unusable for tripod use. Even though that particular feature is a disappointment, the strap's functionality as a hand strap is great in my opinion.
Also, when I purchased a second camera (my K-3) in 2014, I purchased this strap (
http://www.amazon.com/gp/product/B00HTWF9ZI?psc=1&redirect=true&ref_=oh_aui_detailpage_o05_s00) for use on my old K-5 and I put the Pentax handstrap on the new K-3. The Movo is okay, but not nearly as good as the Pentax strap IMHO, anyway for use as a hand strap. However, it does have a female thread for tripod mounting that is centered, unlike the Pentax brand hand strap. For that reason, it probably works better for tripod use, but I've never tried it to know how well it actually performs.
Daryl
