06-25-2015, 11:56 AM   #1
lgbalfa's Avatar
how is this memory card for the k-50?
Toshiba 32GB Exceria UHS-I U3 SDHC Memory Card PFS032U-1EUS B&H
will be shooting a lot of tennis pics on rapid fire so wanted something that can handle the 6 FPS.
thanks
06-25-2015, 12:22 PM   #2
jatrax's Avatar
Speed wise it should be fine 60MB/s exceeds the k-50 write speed. I've no experience with that brand so cannot help you there.
06-25-2015, 12:38 PM   #3
lgbalfa's Avatar
even if the MB/s exceeds the k-50 write speed, is there anything negative about using a card that exceeds that speed or pretty much using something like this would maximize the fastest speed for the camera?
thanks
06-25-2015, 01:54 PM   #4
QuoteOriginally posted by lgbalfa Quote
thanks
Nope. You might even get a faster transfer speed to and from your computer, so the faster the better.
But brands that I recommend would include Sandisk (Extreme series) and Lexar.
06-25-2015, 01:59 PM   #5
jatrax's Avatar
Correct, using a card faster than the camera is always recommended so that you use all the speed available in the camera. There are no negatives to using a faster card, provided the camera can recognize the card. Note that some older cameras will not recognize the newer (faster) cards. But this is not an issue with the k-50, it can use anything out there at the moment I believe.
Do be cautious that the card is a name brand bought through a reliable seller. There have been, in the past, a lot of fakes floating around with poor reliability and performance. I do not know anything about that brand, so I cannot help with that. I use only SanDisk Extreme Pro cards. They cost more but when you consider you are carrying around $1,000 worth of camera equipment I don't feel saving $20 on a card is worth taking a chance on losing images.
06-25-2015, 05:11 PM   #6
j0n4hpk's Avatar
I have a late model Pentax DSLR and use a Lexar class 10 memory card, but I suggest that your card should be at least class 10, no mater the maker,
06-25-2015, 05:48 PM   #7
aleonx3's Avatar
QuoteOriginally posted by j0n4hpk Quote
That is a class 10 plus U3 SD card, which is the most up-to-date card speed standard. I don't see why that card would not work.
Toshiba owns its own manufacturing facility for SD cards; the brands usually seen are PNY cards and possibly others as well. Faster card speed have advantages when xfers files from/to SD card to other media as it will be faster. The question is reliability. As others have pointed out, Sandisk is usually recommended for reliability, however, that does not mean other brands are not good.
06-25-2015, 08:07 PM   #8
lgbalfa's Avatar
i always thought that kingston was at the top of the list for name brand cards.
i remember a few years ago i bought a dane-elec card and never had an issue with them.
just curious, what is maxmum read / write per pentax in the k-50?
06-25-2015, 09:07 PM   #9
jatrax's Avatar
I do not remember seeing anything published by RIcoh. And I cannot find any tests on the k-50, however here is some information on the k-3 which might be useful: https://www.pentaxforums.com/forums/172-pentax-k-3/241594-anyone-worked-out-write-speed-yet.html
I suspect the k-50 would be slower but the test above indicates the k-3 capable of 30-35mb/s. Personally I don't buy anything under 95mb/s today. That is likely faster than you need but gives some future proofing. And the faster speed is used on your PC assuming you have a USB 3.0 reader.
06-25-2015, 09:16 PM   #10
lgbalfa's Avatar
but for shooting sports (jpeg) with the k-50 in rapid fire mode, the 60 mb/s (read) is certainly fast enough for this camera?
06-25-2015, 09:49 PM   #11
Toshiba and SanDisk make the flash memory for most of the other brands. The secret, according to a SanDisk insider (at the exec level), is the SW that organizes the physical memory and allocates space to data as needed. This can greatly influence card write speed and resistance to corruption. Card makers put more or less effort into this code, particularly in the areas of robustness and QA. Needless to say, he rptd that SanDisk sells the chips but maintains exclusivity on their SW as a competitive edge.
I use SanDisk and Lexar exclusively. I wish my photography was as good as my cards ......
card, k-30, k-50, memory, memory card, pentax k30, pentax k50
K-50: Memory card suggestions wanted Suleeto Pentax K-30 & K-50 15 01-03-2015 11:09 AM
Memory Card Issue Pentax K-50 Zoomer Troubleshooting and Beginner Help 6 08-11-2014 06:24 PM
K-5 Memory Card door broke, where or how to fix? pentaman Pentax K-5 & K-5 II 9 04-17-2014 11:02 AM
k-30: how to format a memory card? ccrookston Troubleshooting and Beginner Help 2 08-12-2013 04:27 PM
Memory card for the K-5 Ziggy Troubleshooting and Beginner Help 24 12-26-2011 02:03 AM
All times are GMT -7. The time now is 04:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
