06-26-2015, 04:02 PM   #1
which type of remote for the k-50
Hi guys,
since I love your input
(hopefully my translation is correct xD)
Which kind of remote would you prefer?
cable vs ir
The 3rd party ones are not that far apart (price) theoretically... but what is the practice point of view?
regards
Sascha
06-26-2015, 04:04 PM   #2
QuoteOriginally posted by NoobOnTour Quote
Hi guys,
cable vs ir
regards
Sascha
The IR remote control F is very convenient since you don't need any wires. But there are certain scenarios when a cable is better, i.e. when being in line of sight is an issue.
06-26-2015, 04:09 PM   #3
thanks for the quick reply
damn.. this is exactly as I thought...
I was hoping, as always, for the "one and only" solution
Do you know to which angle I can use a ir remote with the k-50? Am I able to avoid the camera field of view?
edit: I dont need an exact degree
06-26-2015, 05:21 PM   #4
The IR sensor is on the front of the camera on the face of the hand grip. That should give you some idea.
The nice thing about the IR remotes is that they tend to be smaller* and don't require that you fiddle with any flaps/doors on the camera. OTOH, a wired remote allows you to use all drive modes just as if you were pressing the shutter button.
In addition to the Pentax and 3rd-party IR remotes, you might want to consider a phone app. If you own a smart phone with an IR "blaster", there are apps available that do the job. I use DSLR Remote. It was developed using Pentax cameras and works quite nicely to trigger my K-3 from a Samsung Galaxy S5.
https://play.google.com/store/apps/details?id=de.dslrremote&hl=en
* The matter of size brings up another consideration. The Pentax IR remotes use a non-rechargeable, non-replaceable battery.
06-26-2015, 09:20 PM   #5
ramseybuckeye's Avatar
The IR remotes work fine, you can replace the battery, you have to remove a couple of tiny screws, and it's just a common watch battery. I don't remember the size, but it should be stamped on the battery you need to replace. On the K-50 the IR window is only on the front of the camera, it's easy enough to hold it out of sight of the lens and trigger it. Whenever I use a tripod I use an IR remote. Beside the Pentax there are many third party remotes. My third party remote has a lot longer range than the Pentax. It is larger but has a lot of useless buttons. I kind of like the larger size sometimes because it is easier to find in my pocket, and easier to operate when I'm standing out in freezing temperatures with cold hands or using gloves.
I don't believe you can use bracketing or continuous shooting with an IR remote because you have to select one or the other, but everything else is usable. Autofocus with the remote is turned on or off in the menu. I prefer to have it off because I'm going to pre-focus when I compose the photo, I don't want the autofocus to catch something else and change my focus when I release the shutter.
06-26-2015, 09:34 PM - 1 Like   #6
Hi guys,
cable vs ir
regards
Sascha
I prefer radio wireless like this Vello Freewave . Auto focus, bulb and no worries about line of sight or distance, it's rated for 100M.
06-26-2015, 10:11 PM   #7
QuoteOriginally posted by Brooke Meyer Quote
I could see that being very useful in some situations.
06-27-2015, 07:27 AM   #8
I just grabbed one from Ebay for $15......thanks !
06-28-2015, 02:29 AM   #9
Thank you all for your response!
06-28-2015, 12:55 PM   #10
Banned
Ah, but on the Remote Control F, the battery can be replaced. It's just a standard flat watch battery (don't recall the #). There's 2 small screws on the back that need to be removed to reveal the battery. There's only a couple of parts inside. Take a pic before removing the old battery in case you have trouble remembering just how everything sits inside the case.
06-28-2015, 06:20 PM   #11
Just for grins, I downloaded the app for "Pentax DSLR Remote" from "Google Play" to my Galaxy S5... works great on both my Kr & K-50.
06-29-2015, 04:24 AM   #12
sadly my sony does not have an ir port
06-29-2015, 08:38 AM   #13
QuoteOriginally posted by Al_Kahollick Quote
Thanks for the update. I just looked at the item description on B&H and the description has been updated to note the battery replacement. The waterproof remote WP remains a throwaway device, but that is sort of how it is.
12-01-2015, 01:26 PM   #14
f22
QuoteOriginally posted by azappraiser Quote
Great advice! I downloaded this Droid app and it is chock full of features like in this example (screenshot attached), you can set a 12 second initial delay for the first shot, then 3 HDR bracketed shots 0.3 EV each taken 5 seconds apart. You set the values and features you want to use.
12-02-2015, 01:06 AM   #15
Grippy's Avatar
Those apps look good, I will download them later and see what they can do.
I bought a cheap IR remote from eBay, works a treat, from behind the camera you only need to point it at the top and it will work. I also got a cable thingo too but it's too short compared to the one I am used to on my Oly.
k-30, k-50, pentax k30, pentax k50
Remote shutter release for K-50. Dewman Pentax DSLR Discussion 2 03-18-2015 05:03 PM
Which of the lenses from my K-50 are worth using with film? bladerunner6 Pentax Film SLR Discussion 12 12-22-2014 02:28 PM
K-50 Remote for certain use cminer32 Pentax K-30 & K-50 10 08-02-2014 06:13 PM
Which SD card type is best used for the Q? kyuuan Pentax Q 27 11-08-2012 12:33 AM
Which type of RAW (K-X)? jswilson64 Troubleshooting and Beginner Help 8 02-13-2011 01:07 PM
All times are GMT -7. The time now is 09:10 PM. | See also: NikonForums.com, part of our network of photo forums!
