08-25-2015, 10:54 PM   #1
Auto ISO with M lenses in M mode
I've noticed that the P Line button is disabled when Auto ISO is on in M mode. The shutter speed also changes depending on the ISO. Does that mean that light metering is automatically taken in this case? I took some photos and the exposure seems to be fine.
Thank you
08-25-2015, 10:56 PM   #2
QuoteOriginally posted by farhaddad Quote
Thank you
It works like TAv, so yes.
08-25-2015, 11:03 PM   #3
If thats the case, would it still work if I limit the ISO range from 100 - 200 for example?
Nevermind! I've just tried that. Perhaps this make M lenses more useful than I thought! Other than the metering mode, they're almost the same as A lenses, no?
Thank you for your help.
08-25-2015, 11:37 PM   #4
Well you still need to stop-down meter with them. The reading you'd get by default is based on the lens being wide-open.
08-25-2015, 11:57 PM   #5
Fogel70's Avatar
I don't think the camera will stop down the aperture in any other mode than M, if using a a lens with aperture ring in any other position than A.
As when using auto-ISO in M-mode turn the mode into TAv-mode, which is probably why stop down metering don't work with auto-ISO in M-mode.
So it's only M-mode with manual ISO that will fully support manual lenses without A-position on aperture ring.
08-26-2015, 12:08 AM   #6
QuoteOriginally posted by Fogel70 Quote
Oh okay! I got excited for a moment . Thank you for your helps.
08-26-2015, 02:31 AM   #7
Na Horuk's Avatar
Yeah, the difference is that M series lenses will default to Av mode if you choose Auto ISO or any mode other than M (It will say Av on the LCD screen). In Av mode, M series lenses have constant auto-metering and will adjust shutter speed (or shutter speed and ISO, if auto-ISO is chosen), but only for wide open aperture, regardless of what is chosen on aperture ring. This can be useful if you shoot wide open. This behaviour is also useful if you are using fully manual lenses, like m42 or the K-mount of certain third party brands that has no aperture lever at all.
But for some lenses, shooting wide open is not the best choice. In those cases you will need to use M mode with a static ISO number, then you can use green button for the camera to stop down to the chosen aperture, meter, and adjust shutter speed.
Lenses with A on Aperture ring, like A series or modern Samyang lenses, will allow you to use Av mode normally, as well as P and other modes. The difference is that with these, the camera knows the aperture, so you can choose it on the camera body, as with DA lenses (or you can let the camera choose it automatically)
08-26-2015, 02:43 AM   #8
Thank you for explaining further. I was shooting wide open when I tried the Auto ISO feature and it didn't occur to me that it would be different for smaller apertures. The reason I got excited for a moment thinking that a manual lens could work like an A lens minus the in camera aperture control and the evaluative metering!
Again, thank you everyone for explaining.
auto, auto iso, iso, k-30, k-50, mode, pentax k30, pentax k50
Shooting in Manual Mode with Auto ISO BrianS. Pentax K-3 7 02-16-2015 02:35 PM
Changing thumb wheel to ISO in M mode? Fat Albert Pentax K-01 5 03-15-2014 08:21 PM
For video, does auto-ISO work in M mode? jake14mw Pentax K-01 4 01-27-2013 10:13 PM
k10D metering with M lenses in M mode - K200D doing a better job w/ Green button mrpackerguy Pentax DSLR Discussion 8 10-03-2008 11:53 AM
auto ISO in M mode? not option? Akcelik Pentax DSLR Discussion 4 03-07-2007 05:38 PM
All times are GMT -7. The time now is 07:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
