Originally posted by jatrax I don't have a k-30 but there have been a lot of posts on this issue. You might contact Precision or KEH and see if you can get a quote rather than standard rates, you might have to send it in for that though. Another possibility would be to check used k-30 prices and see if that is less than the cost of repair.
k-3II is the new flagship and would be a large step up in a lot of areas, but is still priced at a premium, you might also look at used k-3 or k-5IIs. The only difference between k-3 and k-3II that makes much difference for me is the GPS. If you don't need that look at new or used k-3 instead. k-5IIs is also a very nice camera with similar sensor to k-30 but 14bit, no AA filter and IMHO better build quality.
It seems that both Precision and KEH have moved to a flat-rate model, unless the price is higher than the flat rate. In any case, it looks like used K-30s are in the $350 range, while the flat-rate repair cost is a little over $200.
I don't think I want or need the GPS, so I'd look at the K-3. But for now I think I'm going to go the repair route.
