10-03-2015, 03:32 AM   #1
Weird Vibration and Noise while Switching Off the camera.
Hi All ,
Whenever I switch off the camera off , i tend to get a vibration and noise (something like that) . Is this normal or am I doing something wrong. ?
10-03-2015, 03:35 AM   #2
Na Horuk's Avatar
Is it just a half-second TRRRT sound? You probably have dust removal turned to automatic on shut down. You can change it to off or automatic on start up, or leave it as it is.
Feature, not a bug. Nothing to worry about.
10-03-2015, 03:47 AM   #3
max_pyne's Avatar
leave it on
10-03-2015, 06:55 AM   #4
12345's Avatar
That is probably just the dust removal system. My K-30 did that when I got it except it did it when I turned it on so I set it to do it when I turned it off because it seemed to make start up time less.
10-05-2015, 02:26 AM   #5
Thanks Guys. Yes it was the Dust removal feature which was making it.
k-30, k-50, k-50 / 18-135mm, noise, pentax k30, pentax k50, vibration
Which camera/brand did you use before switching to Pentax and why? axelm7 Pentax DSLR Discussion 105 11-25-2014 10:18 PM
Weird off-focus issue between MF and AF lenses tempelorg Pentax K-5 & K-5 II 6 06-30-2014 10:34 AM
Switching lenses without turning off camera? hcc Pentax DSLR Discussion 48 05-27-2010 01:22 AM
Weird noise on the underexposed part of the subject sash Troubleshooting and Beginner Help 9 11-26-2009 09:45 AM
K10D and weird noise pattern quickpix Pentax DSLR Discussion 14 01-28-2008 03:56 PM
All times are GMT -7. The time now is 06:17 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
