10-12-2015, 02:14 PM   #1
kjfishman's Avatar
How many shots with AA LI battey adaptor
How many shots should I expect with AA Lithium batteries?
10-12-2015, 02:24 PM   #2
Off the top of my head I believe you'll be in the 700-800 range. Certainly longer than the rechargeable battery, which doesn't have as high of a capacity as the one used in the K-3 series.
10-12-2015, 02:54 PM - 1 Like   #3
Shoot off the top of your head very often?
10-12-2015, 03:20 PM   #4
Ex Finn.'s Avatar
I used to get over 1K with my K100d, this was with minimal flash and "chimping"
10-12-2015, 08:28 PM   #5
UncleVanya's Avatar
As above. Loads and loads. 2x the rechargeable at least.
10-23-2015, 10:28 AM   #6
If "in theory" is to be believed, my rechargable AA batteries offer 2000mAh each, and the Wasabi battery is 2300mAh. So about 3.5x there...
10-23-2015, 11:27 AM - 1 Like   #7
UncleVanya's Avatar
QuoteOriginally posted by disord3r Quote
But the Wasabi is at the full voltage and the Li109 (K50 battery not K3) is listed as 1400mAh not 2300mAh and in practice it actually lasts a bit less than the 1050mAh original Pentax battery which leads me to rate it at about 900mAh. I think the more important point is that the AA's are drawn down collectively (in series for voltage) which means the total capacity is equal to the capacity of a single battery (2000mAh or 2200mAh depending on the AA's you have). Essentially a set of AA's has close to 2x the mAh of the Li-Ion OEM battery and slightly more than 2x the Wasabi from practical experience. But the Lithium non-rechargeable AA's are even stronger (3000 mAh or so) and they are less sensitive to drain rate. Ni-Mh AA's drained too quickly (by lots of live view) will have only around 1000mAh capacity.
http://data.energizer.com/PDFs/l91.pdf
10-24-2015, 03:54 AM   #8
kjfishman's Avatar
Thanks, great information!
k-30, k-50, pentax k30, pentax k50, shots
AA li-ion battery G Conklin Visitors' Center 4 11-26-2014 09:13 AM
Macro Handheld -- How many shots to get a good one? EllenJ Photographic Technique 20 06-26-2014 01:41 PM
How many shots from AA batteries ? focusian Pentax K-30 & K-50 18 10-17-2013 08:36 PM
how many shots can be taken with KR battery full charge ? ajaya Pentax K-r 29 09-20-2011 09:58 AM
AA batteries in K-r - how many shots? Popty Ping Pentax K-r 11 08-18-2011 02:47 AM
All times are GMT -7. The time now is 10:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
