10-23-2015, 10:03 AM   #1
Do I have a problem?
I can hear a noise inside my K-50 body when no lens is attached, as if something is loose or wonky. If I hold it as though I were composing a shot then rotate it around the lens axis 90 degrees or so counterclockwise, I can hear a light thunk. I don't generally have problems with the camera's performance, though I do find it hard to get really sharp shots even across multiple lenses; I just assumed I was at fault there.
It should still under warranty and hasn't seen a lot of use in its life. Never been banged up, and its possible it was like that all along and never noticed.
10-23-2015, 10:10 AM   #2
Fries's Avatar
The sound you are hearing, is most likely the anti-shake mechanisme. Don't worry about it!
10-23-2015, 10:22 AM   #3
Good to know. I figured it might be related to the screwdrive and wasn't super concerned, but though I should suss it out before the end of warranty got near.
10-23-2015, 10:25 AM   #4
AquaDome's Avatar
Buy more lenses. Then you won't ever have this problem.
10-23-2015, 10:29 AM   #5
Is there anything more lenses doesn't solve?
10-23-2015, 11:02 AM   #6
bertwert's Avatar
QuoteOriginally posted by disord3r Quote
Empty bank accounts?
10-23-2015, 12:08 PM   #7
Senior Moderator
Parallax's Avatar
https://www.pentaxforums.com/forums/58-troubleshooting-beginner-help/94122-be...ntax-dslr.html
10-23-2015, 02:24 PM   #8
Were to put your shelf for the next lot of lenses when the current one is full? .... oh wait
10-23-2015, 02:38 PM   #9
If ISIS had DSLRs and good lenses they wouldn't be blowing up Palmyra.
10-23-2015, 06:28 PM   #10
macman24054's Avatar
QuoteOriginally posted by officiousbystander Quote
LBA= world peace
k-30, k-50, lens, pentax k30, pentax k50
Do I have a power problem?? BerndM Troubleshooting and Beginner Help 4 08-13-2015 03:43 PM
Do I have a problem with my shutter button digitaleagle12 Pentax K-5 & K-5 II 9 12-02-2014 05:33 AM
Pentax SMC DA 16-50 -- Do I have a problem? TroutHunterJohn Pentax DSLR Discussion 4 01-08-2014 10:54 PM
focusing: do I have a problem? spineguy Pentax K-5 & K-5 II 21 06-09-2011 05:29 AM
Do I have a noise problem ? ben-pentax Pentax DSLR Discussion 3 04-28-2007 05:02 AM
All times are GMT -7. The time now is 09:12 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
