Originally posted by georgethess How is it possible to have dirt (hair mosty 6-8 pieces) on my sensor (really destroyed pics)
Some kits are sold with a regular lens, not a WR version. So make sure you actually have a WR lens.
Next, zoom lenses work like a pump and pull air back and forth through the camera. The mirror also moves and pushes things around. I think the main weakpoint of the WR on that camera is actually the viewfinder? Anyway, different parts move air and particles around. And the digital sensor is static, so it attracts some particles.
I suggest you get a rocket blower and clean the sensor. There are plenty of threads and posts about this, and it should solve your problem fairly well. There are other tools for sensor cleaning if you want. You can even take it to a shop to have it serviced. Rocket blower should be enough. Never touch the sensor with hand or vice, and be super careful if you use a fluid cleaner. And don't mix fluid cleaners from different brands, I was told they can react with each other.
Also, there is an in-camera option that shakes the sensor and cleans it a little. You can set this up so it does it automatically every time you turn on or off the camera. I think its a good idea to have this on, but it might be too late when there is so many particles already.
That said - this happens to ALL large-sensor digital cameras of all brands. Dust, hair,.. it is unavoidable on any DSLR and mirrorless cameras.
Note that hair is actually very very fine and might get sucked into places where a water droplet could not penetrate, because water has a certain surface tension. The WR would probably fail if you submerge the camera or if you pour it with steam. Once the force of the water becomes stronger than the force keeping it out, it will go in.
