01-14-2016, 07:31 PM   #16
Well, I deliberated for a long time, but since KatzEye has closed for sure now, I took the plunge and ordered the Nikon K-3 focusing screen for my K3 from "focusingscreen.com". I missed the cut-off for pre-holiday shipping, so mine won't go out until 4th January. Quite looking forward to giving it a try. I'm a bit concerned as to whether or not it will need shimming, and I've never removed / replaced the focusing screen before, but I guess there has to be a first time
How did it go?
01-15-2016, 12:09 AM   #17
BigMackCam's Avatar
How did it go?
Hi Steve... It went very well indeed. I was fortunate in that I didn't need to use any shims... it's absolutely spot on. I don't have any crazy fast lenses - the fastest I have are some f/1.7 & f/1.8 fifties, but I can focus those with absolute precision. More importantly (for me), I can now focus my wider angle lenses very reliably. Matrix metering doesn't seem to be affected, either, which is great. I haven't used spot metering yet, so I guess there's a chance that might be affected, but even if it is, I don't mind making a small EV adjustment. I'm happy enough with the product that I'll be ordering a second screen to fit to my K3II.
03-28-2016, 01:06 PM   #18
Can i use focussing screen for K-50 on K-500 ?
03-28-2016, 01:41 PM   #19
THoog's Avatar
QuoteOriginally posted by Urnamaster13 Quote
Yes. The K-7/5/5II/5IIs/3/3II/30/50/500/S1/S2 all use the same screen.
03-28-2016, 04:27 PM   #20
deus ursus's Avatar
Does the MF screens hamper the AF or the light metering in any way? It'd be nice to have one, but it'd be a pity if I can't use my AF lenses after installment.
03-28-2016, 04:32 PM   #21
BigMackCam's Avatar
QuoteOriginally posted by deus ursus Quote
I find that matrix metering works fine with these screens, and so does centre-weighted (mostly), but spot metering becomes pretty much unusable. AF doesn't seem to be affected with any of my lenses.
03-28-2016, 06:16 PM   #22
THoog's Avatar
AF is never affected because the screen is not in the path between the AF module and the lens. However, the screen is between the light meter and the lens, so metering may be affected. As BigMakCam says, spot metering is particularly affected because half of the center area may "black out" with slower lenses or in low-light conditions, which would throw metering for that area 'way off.
04-12-2016, 03:32 PM   #23
QuoteOriginally posted by MrA Quote
Have just seen that Katz Eye Optics has gone out of business. (Pentax DSLRs - KatzEye Optics)
I need a split prism focusing screen for my Pentax K50 - can anyone recommend another manufacturer?
I can find one on amazon uk citing suitability for the K5, K7, Kx & Kr, but not mentioning the K50, and in any case possessing many a one-star review.
Alternatively, will the one from my K-r fit the K50? I'd check on the Katzeye website but they've taken all the info down...
Thanks!
Don't know if this helps 4 months later.. taiwanese firm Focusing Screen
Bad Englich -- products seem ok in presentation, although a little pricey.. K10D is mentioned and K50.
Haven't tried yet. Different styles, angled split prism, horizontal, cross. My preference is for a fresnel ring with 45 degree split prism, as found on the old German cameras of the film days.
04-12-2016, 03:45 PM   #24
BigMackCam's Avatar
@frodobaggins - yes, that's the company I used. Good screens
07-15-2016, 11:17 AM   #25
compatibility
Have a split screen salvaged from a zx50, does it matches for a KS2?
Oscar.
07-15-2016, 01:16 PM   #26
QuoteOriginally posted by oscar Quote
Oscar.
The screen is larger, but can probably be cut down to match the size/shape of the K-S2 screen. If the thickness is similar, can be shimmed to work. This kind of thing has been done by other users on this site using new Nikon and Canon screens.
07-15-2016, 05:06 PM   #27
Thanks, Steve, I've reading about for sveral hours and realized that in my case it's no worth taking the time to do it specialy due the various issues involved, like shimming, erratic exposure etc.
First I'll go to the oftalmologist for new glasses, finish my macro bellows with tilt-shift and clean a sticky diaphragma on a 28-200 old Samyang.
By the way, is it worth a macro with tilt-shift? Not shure about it but it will show beautyfully on a shelf. HaHa.
Greetings
Oscar
08-13-2016, 02:16 PM   #28
amateur6's Avatar
Hi Steve... It went very well indeed. I was fortunate in that I didn't need to use any shims... it's absolutely spot on. ... I'm happy enough with the product that I'll be ordering a second screen to fit to my K3II.
Hi! Did you get one for your K3II, and did it fit perfectly as well? I知 so depressed that KatzEye is gone, and I really don稚 want to fiddle with shims... I知 tempted to go back to my K20, but I know I値l miss the higher ISO. On the other hand, if my focus failure rate is 90%....
08-13-2016, 03:46 PM   #29
BigMackCam's Avatar
QuoteOriginally posted by amateur6 Quote
Hi No, I didn't. In fact, I ended up selling my focusingscreens.com screen to another forum member and I've gone back to the original screens in my K-3 and K-5 (the K-3II screen has remained original from the start).
I liked the screen, and it worked well. However, although I originally thought that I had exposure under control with it, I had quite a few instances where I misjudged the difference it made to the camera's metering, especially centre-weighted. And whilst I knew that spot metering was no longer reliable, I missed having it. But that was a personal choice, and I'd still recommend their screens if you're looking for one, and accept the compromises
08-14-2016, 12:21 PM   #30
Split prisms are a waste of time, IMHO. They're not accurate enough. The standard K-50 screen is really good at manual focusing. Why would you want to go to the bother (and expense) of replacing it with something that needs an awful lot of setting up (re-shimming etc.)?
k-30, k-50, k50, katzeye, optics, pentax, pentax k30, pentax k50, prism, split, split prism
Adapting an old Split-Prism Focusing Screen for the Pentax K-x Bruno-C Pentax Camera and Field Accessories 20 11-24-2016 11:50 AM
For Sale - Sold: FS: (Australia/Sydney) Pentax K5 focusing screens. Nikon K3 split prism, Canon ee-S Nuff Sold Items 2 10-16-2014 04:51 PM
third party (split) focusing screens nanok Pentax K-5 4 12-03-2010 08:24 PM
For Sale - Sold: Split-Prism Focusing Screen for Cheap SOldBear Sold Items 4 03-11-2009 02:52 PM
Split Prism focusing screens for K1000 nakey Pentax Film SLR Discussion 11 09-18-2008 07:17 PM
All times are GMT -7. The time now is 07:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
