Originally posted by Canada_Rockies First thing to do would be to clean those contacts. If they are only lightly touching, anything that impedes the data transfer would cause a failure.
Yeah, that was the first thing I did, both on the lens and on the camera
Thanks
---------- Post added 12-14-15 at 12:10 PM ----------
Originally posted by jatrax As noted above give the contacts a good cleaning, buff them with a microfiber cloth. Some third party lenses have mounts that are just a bit 'off'. In most cases there is no problem but rarely they can cause this issue.
Try cleaning the contacts first. If that does not work, double check that the mount on the lens is securely fastened. You might also slightly loosen the mount screws and try to rotate the mount a bit to see if you can align it better. But do that only if you feel comfortable working on a lens, and only loosen slightly do not remove the screws.
Yeah, all is good there, I see two of the pins are depressed a bit so it must be the pin springs not allowing for the pins to make good contact with the camera pins. I have another Sigma 28-90 that I can steal some from, or I may just take them out and visit a locksmith to buy some springs of the same dimension.
Thanks
---------- Post added 12-14-15 at 12:12 PM ----------
Thanks to you both for the quick reply. much appreciated
Kirk
