Originally posted by HuddyBoy So all think the K-30 can only produce one Aspect Ratio. I can now quite trying to change it. I thought with some Canon cameras more than one AR was available. Maby to do that would be confusing to the penta prism viewer. My others were point and shoot. Thanks all for settling the issue....Dan
I don't think that the aspect ratio has anything to do with the prism and the view finder. As Adam said the sensor is 3:2 but the LED screen is 4:3 (or was 4:3). When you are looking through the viewfinder, you are looking at a mirror that is reflecting the image from the lens. If you go to live view and look at the LCD screen, the image on the screen is straight from the sensor. Now, because the LCD screen is not the same ratio as the sensor, you will get an area that does not have a picture on it (letterbox) just like watching a widescreen movie from a DVD on a square screen TV. Pentax changed the LCD screen on the K3's and the K5's so that the ratio between the LCD and the sensor matched.
It could be possible that you can change the ratio on some Canon DSLR, but I wouldn't know about that because I have never owned a Canon DSLR. My guess would be, if you can, it would be the full frames like the 5d that has that feature.
