Originally posted by bigdavephoto The grainy pattern that you are seeing when you look at the mirror through the lens mount is the pattern of the Fresnel of the focusing screen. That might also be what you are seeing though the view finder.
I see! That is a big relief to know
Thank you!
Originally posted by Sagitta FWIW, that lamp photo is (probably) exposing correctly - its a very bright point of dominant light so the camera is throttling down on the exposure to compensate. If you go out on a bright snowy day or a out to the beach youll find things shooting dark as well since the camera is seeing a lot of light and is trying to adjust for it.
Try the same shot with your flash on and see what results you get - I'd bet it will look a lot more 'normal' to you.
I did take the same lamp shot with the flash on and it seemed pretty normal this time around.
I have another question - which lens should i get next for regular street and night photography?
