01-10-2016, 05:37 PM   #16
Na Horuk's Avatar
Yeah, when I mentioned settings like CA and distortion correction, and shadow correction, I should have also mentioned other filters and NR.
Drivangil might also be on to something. Check AF vs. shutter priority.
01-12-2016, 03:33 PM   #17
Have you tried a different / new / fresh battery?
Also see what your frame rate is with Manual focus.
01-13-2016, 07:34 AM   #18
takis63's Avatar
As i wrote above, all is well now. The camera works as advertised omand only when it gets dark it will slow its framerate. I think this is totally natural and friends with other cameras (Nikon, Canon) have reported the same.
I would like to thank you all for your help. I expected nothing less.
Panagiotis
fps, k-30, k-50, k50, noise reduction, pentax k30, pentax k50, rate
M lenses, SR not as effective as modern glass? Surnia Pentax SLR Lens Discussion 12 10-05-2015 05:43 AM
FF could be as (or more) silent as (than) K-3 RuiC Pentax Full Frame 7 12-02-2014 02:16 PM
Photos are not as vibrant as I would like/expect Michele85 Troubleshooting and Beginner Help 9 05-15-2014 08:09 AM
K50 (and 30) sensor same as K5 or not? Kona Pentax K-30 & K-50 13 09-01-2013 12:09 PM
Tamron 17-50mm f2.8 not as fast (bright) as Tamron 28-75mm f2.8 on Pentax K-x, PICS Edgar_in_Indy Pentax SLR Lens Discussion 38 01-10-2011 04:09 PM
All times are GMT -7. The time now is 02:02 AM. | See also: NikonForums.com, part of our network of photo forums!
