02-20-2016, 06:12 PM   #1
kiberkli's Avatar
Four-position Focus Mode Switch
My K-30 is developing a four-position focus mode switch.
I can feel four positions as I move the switch. Switching from AF.S to C is ok, and switching to MF is ok since it's at the end of the range. However switching from MF to C is ambiguous. It feels like it's snapping into a position between MF and C.
Anyone else seen this?
02-20-2016, 07:02 PM   #2
MadMathMind's Avatar
QuoteOriginally posted by kiberkli Quote
"Broken" being the 4th?
I think mine on the K-5IIs can drift midway between MF and AF and stick. It is obvious when the camera refuses to AF which it is. I'm sure it's fine.
02-20-2016, 07:37 PM   #3
kiberkli's Avatar
QuoteOriginally posted by MadMathMind Quote
I'll have to see what develops.Worse case is that it turns into a two-way switch...
02-20-2016, 09:11 PM   #4
aremmes's Avatar
Does it happen when the camera doesn't have a lens mounted? Since moving the switch to MF retracts the focus drive screw, perhaps something on the mount flange (camera or lens side) has a tendency to jam the focus screw.
02-22-2016, 11:22 AM   #5
kiberkli's Avatar
QuoteOriginally posted by aremmes Quote
I did not know that. It seems more pronounced with no lens attached. The drive screw when retracted is slightly off-center and gets slightly caught when extending.
(Sorry for the delay in responding, I was away to a swim meet.)
02-22-2016, 11:30 AM   #6
bertwert's Avatar
My K-50 also does this, never noticed until now when you mention it.
Pos. 1 AFA - Screw drive extended - AF works
Pos. 2 AFC - Screw drive extended - AF works
Pos. 3 AFC - Screw drive half extended - AF works
Pos. 4 MF - Screw drive retracted - MF
02-22-2016, 12:09 PM   #7
kiberkli's Avatar
QuoteOriginally posted by bertwert Quote
Since I now know that this is partially mechanical I'm not that worried. If the switch is aligned with the C then it looks like the mechanical parts are in the right place.
focus, k-30, k-50, mf, mode, pentax k30, pentax k50, switch
Pentax K-3, Manual Mode won't switch to Av, Bulb, but stays in M Mode scotman55 Troubleshooting and Beginner Help 5 10-10-2022 07:17 AM
Four way disabled in 9 point focus mode Nico13 Troubleshooting and Beginner Help 6 12-28-2014 12:23 AM
Four-way Pad in Manual AF Mode K David Pentax K-3 & K-3 II 6 05-04-2014 02:10 PM
K01 - main switch turn off camera in on position when pushed clockwise Foma2 Pentax K-01 5 01-23-2013 03:06 AM
Tv mode in non-A position loikos Pentax K-5 & K-5 II 6 11-13-2012 03:04 PM
All times are GMT -7. The time now is 01:22 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
