Originally posted by niceshot I personally cant verify this as my mirror motor is gone or doesn't work . I think this magnet fix is maybe far fetched , I beleive the real culprit is a weak mirror motor
Motors tend to break due to excessive load, the motor receives a electric load, but finds more mechanical resistance then what it was planned to do, or completely stuck, gets hot and the wire from the coil's melts, with a multimeter you could try to check it's resistance (ohm), but it is hard without knowing the correct values, if the resistance is too low it's kaput, if it is too high or no conductivity at all, kaput it is, best would be to compare with a working one
