Show Printable Version 200 Likes Search this Thread
01-03-2017, 07:03 AM   #256
I used the same method of post #247, maybe I just removed a bit more material, but it is hard to say due to the small size of the part.
01-10-2017, 05:11 PM   #257
Just wanted to follow up with my repair. I've taken a few hundred shots since then and I haven't had any problem with the aperture since. I leave my camera out on a tripod to take picture of my bird feeder so its gotten a lot of power cycles since mid December.
I hope this encourages some of you to try to take this repair on yourself! Happy to answer any questions anyone has if they get stuck during the process!
Cheers!
01-10-2017, 11:14 PM   #258
pentax360's Avatar
In instances where the part is magnetized has anyone tried demagnetizing it?
I don't have a k-30 or K-50 but I just bought this real to real tape demagnetizer and it stops magnetic screwdrivers from being magnetic, so I'm sure it would work with that part.
They're under $30 on ebay.
01-10-2017, 11:57 PM   #259
richandfleur's Avatar
Why not sit your whole K-30 on that thing, nice and easy like...
01-11-2017, 04:10 PM   #260
FWIW, I didn't find my armature to be magnetized what so ever.
01-11-2017, 07:06 PM - 1 Like   #261
QuoteOriginally posted by reh321 Quote
So, what did your correction do to fix the problem?
Reduced the surface area of the armature that the magnet can attract, reducing the holding power of it.
01-12-2017, 03:03 PM   #262
And here is the first K-S1 with an aperture block failure.
Mine has started two days ago with black (heavily underexposured) pictures.
Battery in and out temporarily solved the issue but today the mechanism totally went stuck.
But I have made a very interesting discovery.
Carefully heating up the body (battery out) to 40°C on a radiator cured the problem - completely!
Unfortunately the black picture phenomenon returned as the camera cooled down to normal temperature (20°C).
Now I have to shoot two to five pictures before I get properly exposured photos.
May be this finding will help us finding the cause and hopefully a permant solution.
01-12-2017, 03:09 PM   #263
The heating could have reduced the magnetisation of the armature, if that's what causes this problem.
01-12-2017, 03:21 PM   #264
Not a Number's Avatar
QuoteOriginally posted by marabella Quote
I don't think this is the first but not many reported. I'm surprised there are few if any reports of the K-01 which shares many of the components with the k-30/50. Of course the mirror block is inter-related and the K-01 should be lacking those - but perhaps the cause lies in the mirror block too.
QuoteOriginally posted by HarisF1 Quote
Or just softening of the lubricants. Warming up an old MF lens with stiff focusing ring often makes it turn smoother until it cools down.
01-12-2017, 06:13 PM   #265
AFAIK no one did report a faulty K-S1 in the forum's survey. But that's not the point.
Meanwhile I'm still testing. Results are promising but not satisfying so far.
The camera went from totally dead to a working state now after 1 to 3 black shots.
Perhaps somebody can repeat my procedure and post their result?
Heating up the camera to 40°C should be safe. User manual says 0 to 40. Battery and SD-Card removed. Carddoor open.
I place a thick book between the camera plus thermometer and the radiator.
I let the camera heaten up for 2 hours. Then gave it a burst shot (30-40).
I let it cool down for 2 hours and gave it a burst shot. Exposing it to different light will engage all aperture values. SD-Card not needed.
The second time I have put the camera upside down.
Now I'm continuing with both sides. Same procedure.
If this will fail I'm going to open the camera and try the repair procedure as it's described in this thread.
01-14-2017, 01:35 PM   #266
Now, one day after, the camera is working as it should.
Correct exposure with both aperture and shutter speed from the beginning.
I do believe that heating up the camera's side where the solenoid is positioned did the trick.
I only can confirm this for my K-S1 and of course I don't know how other models will react to this method.
But I recommend this procedure before trying a self repair or sending it to a repair center.
01-14-2017, 02:36 PM   #267
Very Interesting. What made you try this method? Perhaps someone with experience might know why this would work?
01-14-2017, 02:40 PM   #268
heat it up with a propane torch lol
01-14-2017, 02:50 PM   #269
How about the grill, more even heat. (might as well throw a couple of burgers on also.)
01-14-2017, 04:34 PM   #270
QuoteOriginally posted by paolo11 Quote
how about the grill, more even heat. (might as well throw a couple of burgers on also.)
i was thinking microwave it
aperture, aperture block failue, block, block failue repair, camera, cameras, cost, details, failue repair solution, failure, forum, k-30, k-50, k-50 aperture block, mount, nikon, pentax k30, pentax k50, plate, post, repair, results, russian, translator, union, warranty
Wanted - Acquired: KatzEye Focus Screen for K-3 (K-3, K-5, K-5II, K-7, K-30, K-50, K-500), New or LN fwcetus Sold Items 15 05-07-2016 08:01 PM
Why A K-S1 Instead Of The K-50 / K-30? I'm A Pentaxian Pentax K-S1 & K-S2 71 12-24-2015 03:50 AM
Wanted - Acquired: Wanted K-30/K-50/K-500/K-r 12345 Sold Items 13 09-12-2015 09:51 AM
For Sale - Sold: Focusingscreens.com EE-S Screen for K-3, K-5, K-5II, K-7, K-30, K-50 & K-500 Aperturae Sold Items 6 10-06-2014 06:49 AM
For Sale - Sold: KatzEye Split-Prism Focusing Screen - for K-3, K-5, K-5II, K-7, K-30, K-50 & K-500 Eyewanders Sold Items 7 04-15-2014 08:35 PM
All times are GMT -7. The time now is 06:41 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
