Originally posted by reh321 I have no idea what the root issue is, and I'm not convinced anyone else does either.
I am willing to believe that the folk in Calif have found a fix that alleviates the problem, but it isn't necessarily directed at the root issue (*)
(*) Before someone complains about this logic, consider a "slide" {inclined plane} which was incorrectly manufactured, having too much friction, so objects sometimes get stuck partway down. Polishing the plane would address the root issue. However, other solutions, such as increasing its slope or greasing it, might also cause it to work correctly.
I'm with you about the root cause. Wonder if anyone had it repaired in Europe,and knows what the repair was besides replacing the entire block? I was an electronic technician before moving into S/W engineering,and I use to T/S to the component level, but now a days boards are cheaper due to mass production, so techs just replace whatever board is at fault. But the design engineer should be able to figure out the problem, and make the necessary modification.
I feel this is what happens here in the states where Pentax uses Precision camera repair in CT, they just replace the entire aperture block (if indeed the problem). So, if it's not been modified,then the problem will repeat over time. I called and asked the question, and couldn't get an answer, perhaps if I had it repaired and saw the bill, then I would know.
K50 is still working fine, I change the F stop back and forth, small to big, big to small, change the ISO. And it's perfect.
BTW, I have a "cheap" Pentax XG-1 52 X zoom, paid about $200.00, zoom is from 24 mm to 1249 mm, have got nice moon shots. And I love it. I use it when I cycle as it weights 1 1/2 pounds, strap it around my waist (in a bag), and stop for nature shots.
