Originally posted by enyaw Hi, I've followed this thread from beginning to now. I just have a few questions. Are the upgrades that I see being done, doable by your regular joe? I see some of the people that did theirs are engineers, tech, etc. would this be recommended? Also. earlier in the tread someone broke down there cam I think K-50 and what they noticed was a cascade effect. Aperture failure leads to mirror, and something else. If someone is at the beginning of aperture failure, if they switched over to m42 lens, would that prolong or stop degeneration of the camera. Sorry for the run on sentences and grammar. Or let's say, I have ap block failure then went straight to m42 dedicated, can I use the camera for a long time as long as its dedicated to m42 lens. I have a few
and thanks,
I have a K-50 under warranty, not even 1k clicks
bought it june 2016
Don't do anything to your K50 as long as it works.
Everybody starts with learning. But one should also know one's own limits. A French person recently managed to repair the solenoid but damaged other parts. Might happen to an experienced person as well.
But if you haven't done proper soldering yet, then stay away from it. Even it it works out but you produce a bad solder joint, this joint will soon make problems. One has to know about the right temperature for a given solder, how solder has to "flow and cool" and how long you can touch certain parts with the soldertip before damage is done. In this case you unsolder and solder wires either to the tiny pin of the solenoid or you unsolder and solder those wires onto the circuitboard. Both is delicate work and needs hands which know how and what to do!
Otherwise I would recommend to get the proper solenoid and send it with the camera to a trusted person and demand that you want just this solenoid to be exchanged.
Both, the K30 and K50 are great cameras. Absolutly worth to be repaired. So for the latter versions with the solenoid (although I find it difficult to like the KS1)
Your Pentax will work with all manual lenses (not only M42) because you adjust aparture on the lens, the shuttermechanism is not in use.
