Originally posted by photogem
Well, I ordered one for roughly $ 8,50 from China and will report.
Interesting to hear Photogem, although I'm surprised they are not easily available on ebay in Europe because there are many listed on ebay UK. In fact I've just bought two more, having thought my elderly model had failed. It turned out a mains wire had become detached from the pcb, and a quick resolder sorted that out, as well as improving the method of anchoring the mains cable-weaving two wires through cut-outs in the pcb will not stand up to years of wiggling the cable! However having dismantled the iron, I realised it is well made and designed with appropriate insulation where required and a well-made pcb board, just the mains cable anchorage being a weak point. Both replacements were under £12, the more expensive being supplied in a zippered case with more than 30 different bits to enable wood pyrography if you felt so inclined! In fact this second iron should have been identical to my existing one with vented shaft holding the soldering bit, but has an unvented shaft and a slightly different design handle despite the illustration in the handle. It remains to be seen if it works as well!
On a different topic I have started a thread asking if anyone has encountered playback 'solarisation' on their Pentax LCD screen ( images on card are fine). If you haven't seen the thread I'd be interested in you have encountered any such issue before, and what the casue may be.
---------- Post added 06-20-22 at 01:26 AM ----------
Originally posted by slartibartfast01
That is exactly the same as my current model, and the same person I purchased my recent replacement when I thought my original had died-it hadn't! The only difference between this and my original prove dto be the useful inline on/off switch, which alone would have cost almost as much as the iron. The listing is the same I purchased from, and the iron was posted within the UK.
