06-01-2016, 07:19 AM   #106
QuoteOriginally posted by IgorZ Quote
Do you mean the front sides in the photograph above? The word they used in Russian can only refer to the narrowest part, so it would be the edge #3 in the picture. It also makes sense, since the magnet is on top.
Well... I donīt know. See the new picture attached, I am indicating the direction of the arms movement. If that direction is correct, the friction should be on sides 1, 2 and front sides (faces) but I am only an architect ...not a technician...
IgorZ could you please consult this with our Russian friends? I have decided to stop using my camera before the motor is affected and... by the way thank them on my behalf for the effort they have made.
06-01-2016, 07:27 AM   #107
IgorZ's Avatar
My understanding is that it is not really friction that's the problem. Residual magnetism builds up over time in the armature, and then the field generated by the electric magnet is not strong enough to pull the arms away from the magnet on top. That's why they file those edges on top to create microscopic gaps.
06-01-2016, 08:16 AM   #108
But I understand that some of them were solving the problem with lubricant (judged as not a permanent solution though) can a lubricant create a micro gap?
06-01-2016, 11:38 AM   #109
you sound like you have it right I agree file off the top of the horse shoe this way it break the magnetic lock
---------- Post added 06-01-16 at 02:39 PM ----------
QuoteOriginally posted by JoseFF Quote
Igoz is correct I agree with him, it will break the magnetic lock
06-01-2016, 12:02 PM   #110
QuoteOriginally posted by niceshot Quote
Has any one actually demonstrated this magnetism? Paper clips? Filings?
06-01-2016, 12:06 PM   #111
Steve I had mine apart it is definatley magnetic lock. the idea is to remove a littoff of the top to reduce the magnet lock and of coarse clean it ,.. NEXT
06-01-2016, 01:38 PM   #112
IgorZ in one of your translations you wrote: "Basically the guy took armature arms and filed the front and and back of it.....He thought all that was needed was to create some space between the armature arms and the magnet..... My understanding is that he is talking about the front part that you can see, as well as the back of it, but I will keep reading"
My doubt is that you talk about two opposite parts to be filed, did your further reading made you realized that it was only one side to be filed? Could you please clarify? That would be very helpful as all your work has been so far.
06-01-2016, 02:11 PM   #113
ok from what I read if you reduce the top it will reduce the permanent magnets So they say one you depress the shutter that a state of weightlessness occurs there by releasing the actuator mirror and shutter. Kind a like a trigger so to speak . the electromagnet is supposed too overcome the permanent magnet. but over time the horse shoe become magnetized . so by filing the top you decrease the magnetic grab. ok hope you got it
06-01-2016, 02:45 PM   #114
IgorZ's Avatar
Sorry Jose, that's what happens when you translate without knowing the context. Since they referred to the two narrow parts and I didn't know the shape of armature, I thought they were referring to the round part of the armature that is sticking out from the stator (?) around which the coil is wrapped. Since they talked about two narrow parts, I thought it was necessary to file down both front and back of it. That doesn't make sense, now that I know where the magnet is, as well as the shape of armature. Sorry for the confusion
06-01-2016, 02:57 PM   #115
Ok thank you very much Igor. I will prepare to make the repair soon. Now I feel confident enough.
---------- Post added 06-01-16 at 03:00 PM ----------
Niceshot you should try filing the horse shoe as explained by Igor and try not to use lubricants on it. Maybe your camera will come back to life. I hope.
06-01-2016, 03:59 PM   #116
Thx but it is too late for me the motor is kaput But pleat try it before your motor goes kaput. It sounds as if you have been it there already so just take a little off using sand paper and make sure to clean it good luck report back soon. I AM SURE YOU WILL SUCCEED
06-05-2016, 07:50 AM   #117
ok I went back into my camera today to verify that when I depress the shutter switch that 1.5 volt is being delivered to the mirror motor, and it is is getting it. So that means the motor is bad.
06-05-2016, 08:01 AM   #118
IgorZ's Avatar
That's too bad... K-30 parts come up on Ebay, maybe you can get a replacement
06-05-2016, 08:04 AM   #119
I have a focus motor from another camera they look the smame the issue is getting it out
06-11-2016, 01:23 PM   #120
The Pentax K-70 is annouced - I'm curious whether it still has the same shakey aperture mechanism.
aperture, aperture block failue, block, block failue repair, camera, cameras, cost, details, failue repair solution, failure, forum, k-30, k-50, k-50 aperture block, mount, nikon, pentax k30, pentax k50, plate, post, repair, results, russian, translator, union, warranty
Wanted - Acquired: KatzEye Focus Screen for K-3 (K-3, K-5, K-5II, K-7, K-30, K-50, K-500), New or LN fwcetus Sold Items 15 05-07-2016 08:01 PM
Why A K-S1 Instead Of The K-50 / K-30? I'm A Pentaxian Pentax K-S1 & K-S2 71 12-24-2015 03:50 AM
Wanted - Acquired: Wanted K-30/K-50/K-500/K-r 12345 Sold Items 13 09-12-2015 09:51 AM
For Sale - Sold: Focusingscreens.com EE-S Screen for K-3, K-5, K-5II, K-7, K-30, K-50 & K-500 Aperturae Sold Items 6 10-06-2014 06:49 AM
For Sale - Sold: KatzEye Split-Prism Focusing Screen - for K-3, K-5, K-5II, K-7, K-30, K-50 & K-500 chickentender Sold Items 7 04-15-2014 08:35 PM
All times are GMT -7. The time now is 08:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
