06-01-2016, 07:30 AM   #1
Anyone identify this problem? Saving images on K-50
Hi everyone.
Can anyone identify this problem I am having with a K-50? Started happening a couple months ago. I have recently been using the camera to do only sports, so camera is in burst mode.
When I power up the camera and fire a burst of several images, the images fail to save. Sometimes I can find out only by reviewing the images as the camera won't tell me the pics failed to save. Sometimes I find out right away as a I get a memory card error message and the camera's electronics locks up, I can't even turn it off. I end up having to pop out the battery and re-insert it to get the K-50 working again.
The problem goes away if I re-power up the K-50 and wait a few seconds. I usually take a test picture and it is usually fine.
Memory cards are good quality Sandisks. The level of battery doesn't seem to matter, the camera can do this whether it's full or partially charged.
Thanks in advance.
06-01-2016, 07:52 AM   #2
jatrax's Avatar
Format the memory cards in the camera. Each time you put them in.
The most likely explanation is a memory card fault. If it is happening with multiple cards then it might be a problem with the way the cards are being formatted or ejected. For example some computer OS cause problems if the card is ejected improperly. Sometimes a computer format causes issues on the camera.
There is also an SD card formatting application that is recommended: https://www.sdcard.org/downloads/formatter_4/
06-01-2016, 11:22 AM   #3
Sandisk are the most popular memory cards, and therefore the ones that are also most counterfeited. Be 100% sure about your supplier. If bought on-line from a small on-line only retailer, or worse, via a popular auction site, be sure you check they're genuine. Sandisk themselves will help you with this.
06-03-2016, 06:39 AM   #4
QuoteOriginally posted by JohnX Quote
Thanks for the advice. Will look into it.
battery, burst, camera, images, k-30, k-50, memory, pentax k30, pentax k50, save
Can anyone please identify this camera? dianadebraga Non-Pentax Cameras: Canon, Nikon, etc. 10 05-18-2016 06:43 AM
Can anyone please identify this camera? bladerunner6 Pentax Film SLR Discussion 14 04-24-2016 05:47 AM
Can anyone identify this sword? sam-joseph General Talk 17 11-14-2014 10:45 AM
Can anyone identify this lens/teleconverter? Dewman Pentax SLR Lens Discussion 5 09-09-2014 09:00 AM
Saving images TO sd card on k-x Donal Visitors' Center 9 05-30-2012 11:19 AM
All times are GMT -7. The time now is 04:18 PM. | See also: NikonForums.com, part of our network of photo forums!
