06-12-2016, 02:31 PM   #16
bertwert's Avatar
QuoteOriginally posted by Quartermaster James Quote
Sorry. I got the:
Battery Capacity : 15.5Wh/2100mAh
Output Voltage : DC 8.4V (max)/ DC 7.2V (mean)
from the DSTE battery and not the OEM. My bad.
So on paper that battery lasts longer than a set of 2300mA 1.2V AAs...
06-12-2016, 02:37 PM   #17
Quartermaster James's Avatar
QuoteOriginally posted by bertwert Quote
Not necessarily. 2100 is still less than 2300. Assuming, again, everything is in top form. In real life, between these two, I think battery condition and usage pattern are going to matter more than the specs.
Have fun testing!
06-12-2016, 02:40 PM   #18
bertwert's Avatar
I was going by watt-hours...
Have fun testing!
Fun? What is fun?
06-12-2016, 03:58 PM - 1 Like   #19
Nuno Almeida's Avatar
The discharge curve in a Ni battery is a constant drop, that means that at the end the battery may still have charge but may not have enough power to use the device, Li cells are almost a straight line, meaning they will provide full power through all the discharge followed by a sudden drop right at the end, more mah are used
06-12-2016, 04:22 PM   #20
Got rid of swollen battery a long time ago along with Wasabi. Cheap Chinese junk. (IMO).The AA battery adapter is hard to beat,you can get one for 6-8 dollars and batteries for 10-12 dollars.I'll never buy another D-LI190 because they simply don't deliver the best bang for the buck.Sucks when your battery dies without even getting one day out of it.
06-12-2016, 08:51 PM - 1 Like   #21
UncleVanya's Avatar
QuoteOriginally posted by bschriver11 Quote
Our experience is different from one another. I found more life per charge from the Wasabi than the AA holders with good NiMH cells. However I carried both often. I'm sorry you had issues. I have had OEM batteries swell.
06-13-2016, 12:27 PM - 1 Like   #22
THoog's Avatar
My Wasabis are almost as good as OEM. Regular Eneloops do almost as well - I haven't tried the Eneloop Pros, but I hear good things about them.
A big factor is how the batteries are charged and stored. I've got a stacks of (not Eneloop) AA rechargeables that won't last a day. My Dad used the cheap rapid charger from the big box discount store and basically cooked them to death in a few cycles. I only use them when I'm playing around with multiple off-camera flashes in my office. While the Wasabis come with a travel charger, it runs a lot hotter. I prefer to use the Pentax charger when possible. For AAs, I have a Maha smart charger. It wasn't cheap, but considering how much shorter battery life is with the rapid chargers, it probably paid for itself in a year or two.
06-13-2016, 11:31 PM   #23
QuoteOriginally posted by THoog Quote
I have a Maha 8 cell smart charger I got primarily to charge giant 11,000mah NiMH D cells for sailing use. With AAs I have found the deep conditioning function on that charger will revive batteries quite consistently including some that have been in the bottom of the drawer for years. Not sure I could justify the $100Cdn cost of the charger only for AAs though. But it's a beauty.
06-18-2016, 03:58 PM - 1 Like   #24
I got several DSTE Batteries from Ebay....... Had no problems at all and they saw heavy use over almost 2 years ......and still going strong.
They were something like $8 each when purchased in a 4 lot.
07-04-2016, 11:56 PM   #25
I didn't feel like could trust third-party power accessories inside my K-50, so I shelled out for the genuine D-BH109 AA adapter.
I normally keep the body loaded with 4x Eneloops. I keep the charged D-Li109 as the backup battery, mostly due to gear packing ergonomics. The loaded D-BH109 is bigger and heavier than the D-Li109! If I'm on a really long shoot, I pack a second (or third) set of charged AA batteries, and can load them into the D-BH109 if it comes to that. I never worry about my camera running out of power.
I don't keep good data on the Eneloops vs the D-Li109, but my impression is the D-Li109 runs down sooner.
battery, k-30, k-50, k-50 extra battery, party, pentax k30, pentax k50, third
New K-x battery options... Amigo Pentax DSLR Discussion 10 02-26-2016 03:13 PM
battery pack for extra k-3 mariakruse Pentax K-3 9 11-12-2014 12:14 PM
For Sale - Sold: Pentax K-7 w/ 3rd party grip, extra battery, 18-55WR, 50-200WR and more (Worl einstrigger Sold Items 7 03-17-2011 03:16 PM
For Sale - Sold: K-7 Body + BG4 + Extra battery, FA 31mm LTD; DA*50-135mm lens (CONUS) AirSupply Sold Items 17 09-25-2010 10:02 AM
All times are GMT -7. The time now is 04:38 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
