Originally posted by yucatanPentax If you're looking at build quality as the prime factor, the K-3 or K-3ii is the best choice, imo.
The K-70 has a lot of latest advances, but it is a "consumer model" rather than a higher quality "semi-pro model."
Or in the used market, look for a K-5iis. Check the marketplace. The K5s and K3s are higher quality builds. The K-5 would have a sensor very much like the K-50 at 16mp, but have a better body. I don't think anyone has reported this issue happening in the K5s and K3s, only in the K-30s and K-50s.
thanks for the reply, yucatan--I indeed got a brand-new K-3 although I have yet to put it through its paces--but very much looking forward to it.
I appreciate the information.
---------- Post added 10-15-16 at 10:42 AM ----------
Originally posted by NS_Sailor As I continue to read about this problem I'm becoming convinced that it could be a quality control issue with the supplier of the coil assembly as I doubt parts such as this are made "In House" by Ricoh. If Ricoh used multiple suppliers or switched suppliers to supply this part, this could explain why some don't seem to have an issue while others have experienced failures. One way to determine this would be to compare the body serial numbers for the failed units to units that haven't failed. From this information Ricoh, as part of their ISO-9001:2000 Quality Management System, should be able to get an idea when the breakdown in quality occurred, trace the failed part back to the supplier and where the part was manufactured.
I'm convinced you're right NS_Sailor, as Ricoh has a track record going back to 2000 on its cd/dvd media of outsourcing that to Taiwan and most recently, China. Although it may not seem related, the RICOHJPN media used to be some of the cheapest media to buy and yet some of the best to burn provided someone had the right cd/dvd burner (like a Pioneer)...but once they switched their production almost exclusively to China, a LOT of shortcuts were taken to the point it's become junk media or at best barely average. To have that philosophy on hand means the company's willing to take shortcuts elsewhere so it's definitely a quality-control problem, as I can pick up a Canon prosumer model I barely use compared to my Pentax and it always works without problems. In contrast, I used my K-50 regularly for me to where I was averaging 3-4 pictures a day, so if 'infrequent use' were the culprit, I eliminated that. It's clearly and obviously defective manufacturing/lack of proper quality control, as my K-200 never had that trouble and I put 4x the actuations on it without nary a trouble. The K-50 model was obviously flawed and either someone got a good one or got a lemon.
