08-04-2016, 08:56 PM   #1
bhbrake's Avatar
K-50 overexposing when stopped down
I have had my K-50 for a little less than 2 years and have somewhere around 16,000 clicks. I have recently developed an exposure issue that is consistent across all lenses.
In short, if stopped down to f6.3 or more, the camera heavily overexposes. the problem becomes progressively worse, and by the time it hits f13, the pictures just white blobs. It appears the shutter speed is not adjusting properly as the aperture shrinks and is over compensating.I have to progressively adjust the EV as low as -7.0 to correct the problem. If I put the camera in manual mode and adjust the shutter speed based on the metering readout, then the camera overexposes as I steadily speed the shutter up until I hit a mystery point and then the exposure gets very dark almost instantly. It seems something with the internal metering is completely out of whack and can't handle small apertures, as everything works perfect at f5 and below.
Settings:
-multi-segmented metering
-aperture priority
-EV at 0
08-04-2016, 09:00 PM   #2
Sounds like the infamous shutter block failure issue. A repair center can fix this, though it may not be economical if you're outside of warranty as the repair is $150-200 on average.
08-04-2016, 09:06 PM   #3
bhbrake's Avatar
If it is the shutter, then I am not wanting to pay the quoted $175 I've seen to fix a $400 body. I would just as soon upgrade to a K3ii, as I am printing fairly large (36" prints a 300dpi) and pushing limits of the sensor. I take thsi camera all over the mountains with me and shoot in storms and the like, so a more robust camera may be better.
08-04-2016, 09:18 PM   #4
QuoteOriginally posted by bhbrake Quote
That sounds like a good idea! The K-3 won't give up nearly as quickly.
08-04-2016, 09:25 PM   #5
bhbrake's Avatar
Do we have any idea as to whether the K70 retained any of the problem components from the K30/50- it appears to be an odd hybrid of the k3 and k50 as far as features and components, and would be a another potential replacement.
08-05-2016, 03:30 AM   #6
BigMackCam's Avatar
Give your point that "a more robust camera may be better", I'd honestly recommend the K-3 or K-3II. The K-70 is a fine camera, I've no doubt, but the build quality is aimed at the same level as the K-50 and K-S2. The K-3 and K-3II have a much more robust and rugged build quality to them. If the cost of either is prohibitive, I'd suggest a good used example - the number of shutter actuations can be verified with the seller before purchase, and both models have a 200,000 actuation shutter life.
08-05-2016, 07:44 AM   #7
UncleVanya's Avatar
The shutter block problem is more commonly associated with underexposed shots but mine failed in a way similar to what you describe. I did not note and specific aperture ranges Mine was under warranty so I had it repaired.
Do you have any lenses with aperture rings? You could try using them in green button mode. It may work then but with the underexpoure issue I doubt it. M42 lenses or modified k/m/a lenses using manual aperture should work.
If the manual green button works on an unmodified k/n/a lens using the aperture ring there is a post from a guy looking for a cheap body to use with a 50mm f1.2 - you may want to chat with him.
08-05-2016, 11:42 AM   #8
bhbrake's Avatar
I do not have an aperture ring on any of my lenses (see profile for lens list), so I can't test that unfortunately.
I'm headed out to the Colorado national Monument next weekend and think i'm going to rent a K3 or K3II to compare. I'm not sure whether the K3II would be worth the extra money over the K3 though.
08-06-2016, 07:58 AM   #9
For renting to try at a national park get the K-3 II. The only advantage the K-3 has its the built in flash, which you won't use shooting landscapes. With the K-3 II you can try pixel shift and use the GPS to tag your photos, and maybe even use the Astrotracer for some star shots at night. I'm sure you'll love either K-3, and a weekend with the extra features in version II will tell you whether it's worth the extra cost when you buy one. (Yup when, not if. &#128521
I got my K-3 before the K-3 II came out and for the cost involved I don't need to upgrade yet. The built in flash has saved me on three or four occasions, but if I was choosing now I think I'd lean towards the K-3 II. You can bet I'll be drooling over the K-3 III or whatever's next when it comes out though.
08-07-2016, 10:48 PM - 1 Like   #10
bhbrake's Avatar
Well, I bit the bullet and ordered a K-3 from B&H.. should be here by Wednesday. The K-3II didn't have any features I felt I would really use, and the fill flash is nice in a pinch. If I hate it, I can always send it back I guess...
08-08-2016, 01:05 AM   #11
BigMackCam's Avatar
Congratulations on your K-3 - really, an excellent choice, I think you'll love it - there really isn't anything at all to dislike about it, especially if you're already a Pentax user.
08-10-2016, 10:55 PM   #12
bhbrake's Avatar
K-3 came today and initial impression is good. I will break it in on my trip this weekend- hopefully come back with some decent images!
08-11-2016, 12:44 AM   #13
BigMackCam's Avatar
Great news - enjoy! Looking forward to seeing your photos
camera, exposure, k-30, k-50, overexposes, pentax k30, pentax k50, shutter
Aperture stopped when in LV AldaCZ Pentax DSLR Discussion 3 01-29-2016 11:01 AM
Pentax DA* 16-50 PDAF front focus when stopping down. Huy Troubleshooting and Beginner Help 4 03-23-2015 10:09 AM
K-5 - Mark in photos when stopped down Codazzle Troubleshooting and Beginner Help 4 05-08-2012 08:08 PM
K-x aperture problem: always fully stopped down on DA lenses amrocha Troubleshooting and Beginner Help 4 11-03-2011 03:47 PM
DOF Preview in K110D - lens stays stopped down when unmounted? fuzzybabybunny Pentax SLR Lens Discussion 5 12-02-2006 11:04 PM
All times are GMT -7. The time now is 11:24 PM. | See also: NikonForums.com, part of our network of photo forums!
