Originally posted by fstop18 Do you feel the mount is strong enough to support this for extended periods?
It should be fine. The mount anchors into the metal camera chassis and while the screws are small, they rarely pull out in regular use. That being said, there is a case for mounting the lens to the tripod rather than the camera. If the setup feels front heavy and is hard to secure in position with your tripod head without "sagging", a tripod ring or rail with lens support is probably in order, either that or a beefier tripod head. As jatrax noted above, your 17-70 does not fit into that classification and should not be a source of worry.
