09-18-2016, 03:24 PM   #1
K-30 mirror getting stuck,less than 1 year old
Less than a year ago,i asked a friend on mine buy me a Pentax K-30
from amazon co.uk.(cameramarket.co.uk) .
I chose Pentax because I still have the old manual lenses I can use.
However after 6 months I started experiencing this mirror problem.
The seller accepted to repair.
After one month,the camera was sent back to MALTA stating that nothing was wrong with the camera.
However,during the month stay at the seller,he did mention that they came
across the same problem.
I've used over the week-end and the same problem re-surfaced.
ANY HELP PLEASE?
THANK-YOU
09-18-2016, 03:31 PM   #2
Was this a grey market seller? You should have the camera serviced by Pentax, as this is a known issue.
09-18-2016, 04:28 PM   #3
Des
Duplicate thread: https://www.pentaxforums.com/forums/58-troubleshooting-beginner-help/314937-unhappy-k-30-a.html
09-18-2016, 04:51 PM   #4
I thought the aperture sticking was a known issue, not the 'mirror' getting stuck??
09-18-2016, 05:26 PM   #5
QuoteOriginally posted by Steve.Ledger Quote
They are related, though not in a causal way.
09-18-2016, 06:07 PM   #6
QuoteOriginally posted by BANKatBULL Quote
I remember your original posts here, the difficulty forum members had addressing your problems over several months, and also some of the exasperated and/or rude comments you received. Just a few questions:
  • Did you ever purchase a lens designed to provide you with full functionality to use with your K-30 (Pentax-F, Pentax-FA, Pentax DA, or Pentax-D FA)?
  • If so, did the camera work properly with that lens?
  • How have you determined that mirror is not working properly?
If purchased from an authorized Pentax dealer on Amazon, the camera should still be under warranty with Ricoh/Pentax. If otherwise, you may still have remedy from Amazon. When you communicate with them, you must be prepared to give a detailed account of how it is not working. The three questions above are a start to helping you that direction.
Notice that I did not discuss using your camera with legacy (smc K and M) lenses with manual focus and stop-down metering. It was unclear at the time of your post 25 May post whether you had reasonable master of the camera with those lenses. If possible, don't frame your discussion with Ricoh/Pentax in terms of those lenses. Tell them how the mirror is not working. That might include:
  • not up when it is supposed to be up
  • not down when it is supposed to be down
  • somewhere in between when it supposed to be either up or down
  • shadow of the mirror edge in photos taken with the camera
  • shadow of the mirror edge in live view
  • optical viewfinder very blurry and/or dim
  • focus confirmation never works and/or AF using the viewfinder totally fails
Good luck.
09-18-2016, 08:12 PM - 1 Like   #7
Yes, out of curiosity I found this video.
09-18-2016, 09:04 PM   #8
Different camera with somewhat different symptoms (mirror-flop was common on the K-r and virtually absent on the K-30/K-50), but similar idea. The two share a common controller.
09-19-2016, 01:33 PM   #9
I HAVE JUST COME ACROSS THIS.......
THIS IS WHAT I'M GETTING ON MY PENTAX K-30!!!!
ANY IDEAS HOW TO GET RID OF THIS PROBLEM FOR EVER,PLEASE.
THANK-YOU.......Steve.Ledger
---------- Post added 09-19-16 at 10:39 PM ----------
PLS C THIS.THKS.
PLS C THIS.
THKS
09-19-2016, 02:19 PM   #10
PLS C THIS.
THKS
It is possible that one of your vintage lenses has a jammed aperture mechanism and is interfering with operation as in the video. To rule that out, remove the lens from the camera, set the aperture at its narrowest setting and flick the aperture actuator lever with your finger. The action should be snappy and without hesitation and there should be minimal resistance at all points in its throw. If such is not the case, there is a problem with your lens that may or may not be causing problems with the camera.
Please consider my previous post. It may be that there is a problem with the aperture/mirror controller on your camera. If so, it is not something that you can fix yourself and is something that should be handled by Ricoh/Pentax, Amazon, or the actual seller. Which one depends on the details of your purchase.
BTW...USING ALL CAPS IS CONSIDERED TO BE SHOUTING ON MOST FORUMS
(...FWIW, the video was produced by a PF member. I first watched it when the K-r was current product and mirror flop was a concern with that camera...)
09-19-2016, 02:31 PM   #11
Thks for your reply.
I'll see to it one of these days and get back to you with good news.
Rgds & g.night
Victor-Malta.
aperture, camera, cause, dslrs, flop, k-30, k-30 mirror, k-50, malfunctioning, mechanism, mirror, pentax, pentax k30, pentax k50, pls, youtube
Q Battery Life-A question for those getting less than 100 shots per charge cjfeola Pentax Q 9 09-05-2014 10:32 AM
Mirror-less cameras hanging on to their sales better than DSLRs per CIPA philbaum Non-Pentax Cameras: Canon, Nikon, etc. 22 06-02-2014 09:57 AM
Getting a K-30 sooner than planned. bluenose Pentax K-30 & K-50 6 10-04-2012 09:51 PM
The sigma 10-20 is acutally $30 less than online price liukaitc Pentax SLR Lens Discussion 2 08-03-2012 09:01 AM
I May Be Getting That K-30 Sooner Than I Thought!!!! magkelly General Talk 2 07-12-2012 06:23 AM
All times are GMT -7. The time now is 03:36 AM. | See also: NikonForums.com, part of our network of photo forums!
