09-26-2016, 12:07 AM   #16
??? I looked in the K-3 manual to find where this is explicitly state but with no luck. It is implied though. The K-1 manual completely lacks detail documentation on the feature. For the K-50, the manual states multi-segment mode only as you stated.
That is what I meant then. In the older 77 segment metering systems it is explicitly mentioned that the linking only works in matrix. With the new RGB sensor models it works in spot mode as well, and as such no restriction is mentioned.
af, ballet, camera, focus, grid, iso, k-30, k-50, middle, pentax k30, pentax k50, pic, spot
Newbie, when to use AF-S and AF-C, spot and multi point, Help, please! KPsplash Troubleshooting and Beginner Help 8 08-12-2016 09:36 AM
Select AF point(s) vs. single (spot) point ... any difference in accuracy? jpzk Pentax K-3 35 05-06-2016 05:31 AM
AF Active Area, which one? RyanS Pentax K-30 & K-50 6 10-03-2013 07:00 AM
Linking Spot Metering to AF Point radeg Pentax K-5 4 11-26-2012 06:05 AM
Question about AF Active area and AE metering AroundTokyo Pentax K-30 & K-50 5 11-03-2012 08:28 AM
All times are GMT -7. The time now is 09:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
