11-21-2016, 12:38 PM   #1
Pentax K-30 lenses interchangeable with newer Pentax DSLR bodies?
I own a K-30 which has developed the underexposure issue.
I've found a thread where apparently some folks in Russia have found a way to tear down and fix the camera, so I'm planning on trying this as I'm handy with electronics and don't want to pay some $200+ to send it off to be repaired. In case I fail though, is there a chart or other docs that might indicate whether the lenses that came with my K-30 (e.g. Pentax brand 18-55 mm autofocus) would be compatible with newer Pentax models?
Thanks in advance for any help!!
11-21-2016, 12:39 PM   #2
Otis Memorial Pentaxian
photolady95's Avatar
If they work on the K-30 they'll work on newer Pentax cameras.
11-21-2016, 12:43 PM   #3
QuoteOriginally posted by photolady95 Quote
+1, and good luck with the repair.
11-21-2016, 12:57 PM   #4
Medex's Avatar
QuoteOriginally posted by Darth Continent Quote
You still can use any Pentax lens with your faulty K-30 if the lens has aperture ring. Simply choose the desired aperture value on the lense, and camera will close it no more than you chouse.
11-21-2016, 01:06 PM   #5
The Squirrel Mafia's Avatar
If you end up buying another camera, you could always use the K-30 as a "take your time & frame it" camera by using old Pentax manual lenses that have manual aperture rings.
Manual Focus Lens Choices for Pentax - Articles and Tips | PentaxForums.com
^ Once you set up the camera for that, it'll work & expose lenses with aperture rings properly.
The K, M, & A series lenses don't have autofocus, but I believe that the F & FA lenses will.
11-21-2016, 01:15 PM   #6
Thanks all for the responses!!
My lens doesn't appear to have an aperture ring; it has one for manual focus, and another narrower one which appears to be for zoom. I will give the Russians' fix a shot and hope for the best; worst case I may buy a newer Pentax body.
11-21-2016, 03:18 PM   #7
Then it comes to Pentax lenses, an older lens will always work on a newer DSLR. No exceptions to that rule so far!
interchangability, k-30, k-50, k30, lens compatability, lenses, pentax, pentax dslr, pentax k-30 lenses, pentax k30, pentax k50, underexposure
Using Old M37 Takumar Lenses on newer Pentax Bodies - Light Leak? hagiri_11 Pentax SLR Lens Discussion 12 01-25-2015 04:57 PM
Autofocus of DSLR Lenses on Pentax Film Bodies UlrichSchiegg Pentax Film SLR Discussion 24 04-28-2014 01:25 PM
PENTAX K-30 lens-interchangeable digital SLR camera wins iF Product Design Award 2 ogunturkay Pentax News and Rumors 11 12-31-2012 07:29 AM
Old Pentax lenses on Pentax DSLR bodies Balisarda Pentax SLR Lens Discussion 6 11-30-2010 06:30 AM
All times are GMT -7. The time now is 06:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
