12-20-2016, 06:27 AM   #16
Great Job. ths.
btw can u make a video?
12-20-2016, 07:41 AM   #17
altopiet's Avatar
Great, I just don't care anymore. 1st problems at 12K replaced under warranty, now after 38k, starting again...currently using M42 lenses, but I feel my patience slipping, my K-30's imminent death is a fact, either bashed in with, or against a rock....
12-20-2016, 07:48 AM   #18
BigMackCam's Avatar
QuoteOriginally posted by altopiet Quote
That would be a shame. If you didn't want to fix it, there'd be plenty of people willing to buy it - or you could donate it to someone who could fix it for their kids or someone unable to buy a camera. That would be a lot more satisfying than destroying the camera, I'd think...
12-20-2016, 08:26 AM   #19
Not a Number's Avatar
Too bad you are in South Africa. If you were in the US perhaps you could have made arrangements with the OP to send you camera to him and he could make a video of the DIY repair using his repaired camera. Such a video would be invaluable.
12-20-2016, 08:37 AM   #20
altopiet's Avatar
That is the problem, it is just not worth it to try and repair, first time took 4 months...
Luckily I bought my K5iis while the K-30 was in for repairs the 1st time, and that seems to be going very well
12-20-2016, 01:06 PM   #21
pentaprickle's Avatar
Very interesting reading and a great DIY solution.
One point I'd add, coming from a background in computer servicing and repair, would be to take extreme care to ground oneself to eliminate the static charge that can build up in the human body by such simple things as walking across a nylon carpet.
The hair-thin wiring in electrical circuitry can easily be burnt out by electrostatic discharge (ESD) with the worst result being that you're not aware of any such damage and have no clue as to why your device suddenly no longer works.
When working on computers it's relatively easy to at least equalize the static charge by gripping the metal chassis of the computer before starting work, but it would be harder with a small device like a camera.
In my workshop I connected a bare copper wire to the earth pin of an ordinary electrical socket and would just grab that for a few seconds before going near any circuit boards.
Some servicemen wear a bracelet that's connected by wire to an alligator clip on the computer chassis but I found my method easier and less hampering.
12-20-2016, 01:14 PM   #22
I think you are one of the very few, if not the first, to report a second failure after repair. Have you used the camera much after the repair or has it sat unused for long periods of time (several months)?
12-21-2016, 12:47 AM   #23
altopiet's Avatar
Not used that much, about 26000 clicks in 2 years....I believe the replacement part was probably one of the original defective bunch, but at this stage I can't take up with the shop i bought it from, they went belly up, and I don't have the patience to even try and get anywhere with Pentax distributors in South Africa, I've got enough stress in life as it is.
Funny, the K-30 was the only camera that I've bought quite soon after it became available, the others were all at the end of their cycle, and I never had problems with those, so lesson learned
12-21-2016, 01:23 AM - 2 Likes   #24
I've never been an "early adopter". When it comes to computer equipment I tend to buy one generation behind the latest equipment because it is well established with all the major bugs worked out.
12-21-2016, 07:29 AM   #25
retired sw engineer
reh321's Avatar
I guess "not that much" is person dependent. At my historic usage, it would take me over thirty years to raise the shutter count by that much.
12-21-2016, 07:40 AM   #26
altopiet's Avatar
QuoteOriginally posted by reh321 Quote
I did a lot of school sports with it in that time, combined with old slowpoke DA55-300, and sometimes a bit of spray and pray..., but with the kids out of school now, doing very little shooting at the moment, actually trying to kick-start the enthusiasm for the hobby at the moment
12-25-2016, 10:19 PM   #27
xunwp's Avatar
Thank you for the detailed disassembly instruction.
I tried to repair my K-30 last night and it looks I did it. The aperture works normally with both AA batteries and Lion battery, at least till this moment. Cheers!
I filed two ends of the "horse shoe", following the advise from our Russian friends. https://www.pentaxforums.com/forums/151-pentax-k-30-k-50/321871-k-30-k-50-ape...ailable-2.html
I prefer the Russian solution because in this way the magnet can still hold the horse shoe reliably while the actuation between them is weaken.
Please forgive me for my poor English.
12-26-2016, 12:58 AM   #28
swanlefitte's Avatar
Good to hear more are fixed. I am curious if just pulling the shoe off the magnet would fix it, at least for a while.
12-26-2016, 02:02 AM   #29
altopiet's Avatar
For those of you who tried the fix, how long did it take?
12-26-2016, 02:38 AM   #30
xunwp's Avatar
It took me about two hours from removing the first screw to assembling everything back, including about one hour to file the "horse shoe" and test the actuation force again and again.
But I have spent many hours to search solutions, search how to disassemble the body, and decide to do this by myself.
By the way, I printed this as a screw map to keep all screws in their position. Transparent double-sided adhesive is very helpful in case you move the paper by accident.
aperture, board, bottom, camera, force, frame, horse, k-30, k-50, magnet, pentax k30, pentax k50, photo, post, replacement, rick, screw, screws, shoe, solenoid, teflon, time, wires
K-30 / K-50 Aperture Block Failue - Repair Solution available Altglas Pentax K-30 & K-50 885 02-18-2020 12:05 AM
K-30 Aperture control and battery problem mgvh Troubleshooting and Beginner Help 10 10-21-2016 06:56 AM
K-30/ K-50 Aperture DIY Repair richandfleur Repairs and Warranty Service 25 07-30-2016 03:13 PM
K-30 Aperture lever - Convert to IR, fix it , flog it, or bin it? Ian.morgan Repairs and Warranty Service 17 05-02-2016 09:27 AM
All times are GMT -7. The time now is 11:41 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
