10-09-2018, 01:42 PM   #76
reh321's Avatar
QuoteOriginally posted by photogem Quote
I have just ordered the "made in China" white solenoid (allthough I don't need it) and will take photos as soon as it has arrived.
So some of the "white" solenoids are made in China. Do you know whether they are also made of teflon, as the Japanese ones are?
10-09-2018, 05:55 PM   #77
Not a Number's Avatar
QuoteOriginally posted by reh321 Quote
And it is possible that green ones are made in Japan too. Yes, you can get PTFE in translucent green.
10-10-2018, 10:58 PM   #78
No, the green ones are all made in China.
10-19-2018, 07:10 PM   #79
Member hnikesch has purchsed this complete aperture block recently from US-Camera. His has the green solenoid
10-19-2018, 08:57 PM   #80
And you know this how?
BTW: Taiwan is the Republic of China.
10-20-2018, 10:02 AM   #81
Because I know the original manufacturer from Japan, who moved manufacture of the solenoid outside Japan
to the People's Republic of China, i.e. in Jiansu.
They also have an office in Taiwan but manufacturing of our solenoid was in Jiansu.
01-13-2019, 02:17 AM - 1 Like   #82
Impuls needed to actuate green and white solenoids
QuoteOriginally posted by LSAGuy Quote
I bought the complete replacement assembly with the white solenoid from USCamera for $35. Anyone replaced the whole assembly? Any suggestions would be greatly appreciated.
Rick
---------- Post added 10-02-18 at 07:26 AM ----------
I just compared the new assembly with the photograph of the solenoid on page one of this discussion. The difference in the new board (mfg date of 9/9/2017) is the neodymium magnet has been moved up so that there is a 1.5 mm (eye ball measurement ) gap between the magnet and the plastic coil bobbin. This seems to support the argument that the fix reduces the magnetic force drawing the plunger in.
Rick
Last week I received a Aperture controll block from USCamera which they call the Diaphragm Control Block . It was an expensive deal because of added VAT.
It has the China made green solenoid on it.
But it was a very useful buy because I could do some tests with it:
With the China green solenoid the release time of the horseshoe was 10 ms
Then I installed a white solenoid from a defunct Pentax K10D: Release time was 2 ms!
This explains what I always felt I heard as a difference and noticed also when I did a series of shots:
With the white Solenoid the K30 (and the others) shoot faster and more precise.
I have several times asked member LSAGuy to upload a photo or send me one of his block which he claimed had the white solenoid on it.
He never did, he wrote to me that he did not install the block into his body but purchased an used Pentax K20D instead.
I very much daubt that he got it with a white solenoid because several people I know of have meanwhile ordered the same unit:
All with the green solenoid!
Logic! Because the white solenoid is no longer manufactured since a long time!
I know that somebody was able to buy some white NOS (New Old Stock) solenoids in Tokyo Akihabara but I never found any direct link where one could get them directly from Japan
02-08-2019, 03:23 AM   #83
Addition Febr. 8th 2019:
Same test but with a stuck green solenoid:
it took about 110 ms to get the green solenoid to move.
Which is not the impuls the K30 gives, it would go damaged.
We continued over many times to "fire the solenoid" with those 110 ms and after a while it was able to actuate with the same 10ms as a green solenoid which was o.k. Yet: If one waited for roughly 15 minutes one had to start again with 110ms.
It seems to me that the plunger magnetizes quite quickly and then is saturated. Continuous firing seems to demagnetize the plunger a little bit. But even after many rapid fire actuations there remains some magnetism in the plunger due to the fact. My theoriy is that the opposite magnetic force induced in those two coils is not enough to demagnetice enough due to the fact, that the holding permanent magnetic force of the green solenoid is already higher than the holding force of the made in Japan white Solenoid!
This could explain why Pentax bodies not used for some time and even with low shuttercount do get affected much more than those in regular use and high shuttercount. Possibly more factors might well play a role as well.
We then installed a modified green solenoid into the circuit: it was modified via sanding the plunger.
It worked well enough, also the snap obvously sounded different. There was no difference to be noticed in how the mechanism linked with the plunger moved, we colour-coded the white wheel to see when the shutter would be wide open, closed and in between. All this worked alright.
The impuls to actuate it was about 6ms, so better than those 10ms of the green alright solenoid but still 3x worse than those 2ms of the white solenoid.
We sanded the plunger slightly more but noticed occasional faulty movements of the mechanism. With slight more sanding the force of the spring moving the plunger
downwards was too strong, the magnet could not hold it anymore. The solenoid was useless. I then installed it into the flash circuit of a K100D but no luck either.
The solenoid was finished now.
02-11-2019, 12:32 AM   #84
One question
First thank you for your effort to try to understand this problem.
I have a question about this.
The measurements made on the solenoid would be the same with eneloop batteries?
02-11-2019, 03:24 AM   #85
I can't tell, because I didn't try, no eneloops in my house anymore.
But as eneloops do have different characteristics I strongly guess measurements could vary!
Nevertheless, allthough some could run their Pentax longer using eneloops instead of the Li-Ion battery, later on many develop the same problem, just delayed.
I strongly believe that as soon as the problems starts, it is best to act then and not to wait, because further damage can occur.
Damage similar to applying the dreaded sanding method.
This affects the mechanism which is actuated by the solenoid itself:
This mechanism is then more difficult to move, it seems that the lever on which the plunger sits has more resistance to be moved, possibly due to misalignement of one of those wheels with sit on the backside of the complete block. Those wheels run in bearings themselves and get out of alignement due to the sloppy movement of the sanded plunger.
But this is (yet) theory.
04-27-2020, 06:32 PM   #86
!!!!!!!!!!!!!!!!!!!!!!!easy fix!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Temporary?
OK so my $189 K-30 that I scored from ebay started this same issue and got worse and worse till it was unusable. And it happened FAST like over the course of a month. So before buying another K-30, (because I have little free time these days) I found the following in the comments on youtube and it worked for me. MY CAMERA IS WORKING PERFECT NOW! I shut the camera off, and left it off for about 10 minutes and tried it again... and its still working perfectly.
SO I copied and pasted this straight from youtube. Hope it helps someone. BTW I did the FIRST fix and it worked. Can't vouge for the second fix as I haven't needed to try it yet.
COPIED FROM YOUTUBE:
Another hack to get this fixed. It works for me on my K-30
1. Go to Menu > keep pressing the right on the 4-way button until you see the "spanner" icon > Go to 3 > Dust Removal > Select both Startup Action and Shutdown Action
2. Now switch off and ON. You will notice the camera stutters every time you off or on the camera
3. Go to Home and press the right 4 way key (timer icon) > Choose Continuous Shooting (Lo) and press and holder picture shooter button to continuously shoot pictures
4. Now choose Continuous Shooting (Hi) and take continuous pictures
By now the aperture would have set and issue resolved. Again works for me.
Show less
2
View 2 replies
Jon Braid
1 year ago
This other method worked for my camera, they don't like not being used for extended periods and the aperture motor sticks.
1.) Go to the camera menu to button customization and define the raw/FX button to "optical preview".
2.) Use Manual or AV mode and dial in an aperture other than open wide.
3.) Press the raw/FX button 10 to 20 times ( I did so). Every press you should hear the aperture lever working.
4.) Take some shots. At this point my K-30 did correct exposures with some exceptions. So I repeated the procedure until no wrong exposure occurred.
You may have to repeat several times.
Good luck!!!
Show less
04-27-2020, 10:10 PM   #87
You got answers already HERE
You will have to repeat often and thus you do stress not only the solenoid (that by itself won't be a problem really, it is already defunct) but you stress the complex mechanism which then can result in misalignement and in some cases the spring of one of the wheels which is very important:
jumps out and is impossible to fiddle back in because being tangled up:
aperture, board, bottom, camera, force, frame, horse, k-30, k-50, magnet, pentax k30, pentax k50, photo, post, replacement, rick, screw, screws, shoe, solenoid, teflon, time, wires
K-30 / K-50 Aperture Block Failue - Repair Solution available Altglas Pentax K-30 & K-50 1050 12-03-2023 12:25 AM
K-30 Aperture control and battery problem mgvh Troubleshooting and Beginner Help 10 10-21-2016 06:56 AM
K-30/ K-50 Aperture DIY Repair richandfleur Repairs and Warranty Service 25 07-30-2016 03:13 PM
K-30 Aperture lever - Convert to IR, fix it , flog it, or bin it? Ian.morgan Repairs and Warranty Service 17 05-02-2016 09:27 AM
All times are GMT -7. The time now is 08:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
